f-n cam only car runs like crap
Old 11-27-2007, 03:36 PM
Ping King's Avatar
Default f-n cam only car runs like crap
01 ss runs like absolute ****. Car sat for a few weeks with a battery that was at 9 volts or so. Charged it up...runs like complete garbage. seems like its only running on a few cylinders because some of the header primaries are not hot.
previous to this the car had no other problems. I also did motor mounts, but checked the crank position sensor to make sure the wires were not pulled out. Additionally i checked the coolant temp sensor.
Im going to reflash a stock tune back in to see if somehow that helps. Im going to also do a leak down of the cylinders and check everything else. I have spark in the cylinders.
Im so flustered now all of my mechanics experience has gone out the window. Anyone wanna chime in, maybe itll spark something in my brain.
Old 11-27-2007, 10:52 PM
Demon Of Dreams's Avatar
have fuel?
Old 11-27-2007, 11:06 PM
Disturbed Bird's Avatar
did you retune it? may be plugs
Old 11-27-2007, 11:10 PM
01'WS6's Avatar
Leave the tune in it. Assuming it was good before. It is going to take a few cycles for the iac tps etc. to settle out where they need to be after a dead battery. When the battery goes that low then the car loses all memory it had for the sensors and has to relearn it all over again.
Old 11-27-2007, 11:37 PM
Ping King's Avatar
plugs were all soaked in fuel. Car used to just start right up cold. Previously i pulled plugs..let them dry, and a few days later went to start it...same ****..soaked again.
Old 11-28-2007, 12:23 AM
haacer's Avatar
I haven't run into this but it sounds like something that could be fixed by the flood clear mode where you crank and hold the pedal to the floor... Anyone?
Old 11-28-2007, 10:12 AM
Ping King's Avatar
when i start the car i have to put it in flood clear mode, then its only on a few cylinders.
Old 11-28-2007, 12:46 PM
keliente's Avatar
Providing the mechanical work was done correctly, it's probably all in the tune. A lot of times cam-only cars need a lot more driveability tuning than one might think
Old 11-28-2007, 02:16 PM
krayzie7th's Avatar
has it ran good with the cam before? or ever since you put the cam it runs like crap?
Old 11-28-2007, 03:23 PM
Ping King's Avatar
ran great before which is what is driving me nuts..ran fine before i stopped driving the car...had to charge the battery..and now im stuck with this bullshit.
