using coke on a seized engine?
Old 01-24-2008, 04:52 PM
Dskeet6's Avatar
if your motor is seized from sitting and rust accumulation and the starter will not crank the motor................ personally i would just roll that biotch down a hill and pop the clutch..... if that doesn't get things moving....
Old 01-24-2008, 05:56 PM
T/AWS6969's Avatar
Talking
Fully boost the flux capacitor!! That will crank it over!!!LOLOOL
Old 01-24-2008, 06:03 PM
Cchris1109's Avatar
i heard if you pour cement in the engine it will make it stronger too, anyone heard this?
Old 01-24-2008, 08:03 PM
redrider4's Avatar
Yea man!! I do it to every new F body i get! Works real well. Makes the motor immune to nitrous. Dropped my time a whole second! Highly recomended.
Old 01-24-2008, 11:13 PM
Dskeet6's Avatar
i throw a 50/50 mix of octane booster and muscle milk every 3 fill ups on the tank
Old 01-25-2008, 12:22 AM
SOLO Z's Avatar
here this should help clean your motor
http://kalecoauto.com/index.php?main...&products_id=7
Old 01-28-2008, 03:14 PM
Cronic_Moronic's Avatar
It isn't cement but it is close; it is a product called block fill and it is NOT for a street engine it is designed for drag racers that need to have the cylinder walls as rigid as possible (for example a buddy of mine has his block 3/4 filled with block filler. he is running a 300 shot direct port on a drag car.) The draw back to this is that it really hampers the engine's ability to cool itself.
Also coke in the engine will seize it. Had some kid pour a bottle of fruitopia into the gas tank of my truck back when i was in highschool. Completely sugar locked the engine.
Anyway if the engine is seized due to lack of oil the only way you're going to get it to turn again is a rebuild.
Old 03-05-2008, 12:44 PM
Seized's Avatar
Un-seizing a seized engine seems to be a popular topic, but almost all the posting I’ve seen are more entertaining than useful. I’ve found only one website and one product that takes seized engines seriously. Engine Release solved my problem.
web site www.enginerelease.com
Old 03-05-2008, 01:33 PM
meandmyls1's Avatar
You can use muratic acid on old rusted iron blocks. Like anything else you don't just pour it on and let it do the rest. You have to do a few things. The acid will eat the rust mainly and pit the iron. But it attacks the corrosion which is mainly whats holding the pistons in the cylinders.
Once it's done you neutralize it and tap the pistons out. Then send it to a machine shop to be bored out, usually .060 on old sbc, bbc and other thick iron blocks.
There is nothing that can be poured in the sparkplug hole of a seized up assembled engine to make it run.
Old 03-05-2008, 01:35 PM
chavez885's Avatar
nice spam cocksmoker
Old 03-05-2008, 01:39 PM
signal12's Avatar
Take out the spark plug, throw in a mentos and some coke???
Old 03-05-2008, 02:02 PM
  #32
05 GSXR 1XXX's Avatar
LOL at all these post...
just tear it down and rebuild, just wasting your time with trying to unsiez.
Old 03-06-2008, 09:25 AM
  #33
chemicalstylez's Avatar
Originally Posted by unit213
Maybe dump some sand in your engine to port & polish the heads too?
Or perhaps try a little sugar in your gas tank?
I hear sugar makes your car run sweeter
Old 03-06-2008, 09:30 AM
  #34
landonew's Avatar
LOL!!
Quick Reply: using coke on a seized engine?
