idle problem.
idle problem.
sup guys,Well i hit 100,000 miles and having a idle problem. It would set at 7-800 rpms and jump up to 1,000 then back down. I am saying it is vacuum leak for sure but dont were. I replace the iac already so u count that out.
Thanks for the help.
i took the egr pipe out of the intake and cut it. the pipe o-ring isn't that simple to seat. i'm almost positive that mine is leaking there. you might as well try it. it's only like a buck.
Check the rear line going from the drivers side valve cover to the PCV valve, behind the intake. Mine was completely corroded off at both ends. Also check that the line going to the TB isn't cracked or overly worn. Also i see you have a 98. I would check the EGR seal going into the intake. Thats a very likely culprit. Good luck!!! I know first hand how much of a bitch it is to track down a vacuum leak.
