OMFG window motor install
Last night i changed out the passenger window motor. All i have to say is, that was a lot more difficult and frustrating than most people on here make it out to be. Shoebox's site was helpful but the pictures of where to cut the holes are horrible. i ended up cutting probably 10 holes untill i found the 3 rivets. Then my drill bits kept breaking. After i got the rivets out it took 20 minutes to finish. Took me 3 hours to get the rivets out.... If you have a window motor going out, have fun!!!!!
and for every one that is going to say "oh man that was so easy, you just suck",
Nah, say it aint so. I've done a few of them by now - you just need to get those holes drilled right and its not that bad.
You should really add relays for you motors - give them a longer life, better speed, and not have to worry about replacing them any more.
My mistake when I did my driver side was not relubricating the track with grease and ended up ripping the rubber guide out of the metal plate at the rear of the window. I agree....more trouble than it seemed to be.
LS1TECH & Trucks Sponsor
It might be bad the first time, but once you've done one you shouldn't have any more trouble the next time. Don't worry, there will be a next time. . .
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
It took me a while to get it my first time, but I haven't spent more than 20 min on an install since figuring it out. You got the idea of how to do it now, hopefully you learned something that will help you next time.
It really helps to have an extra set of hands. Also, Shoebox's guide was helpful. I went out and drilled close to where I thought the pictures resembled. I was dead on with 2 of the holes and slightly off to the right on one. It wasn't as bad as everyone makes it.
You use a relay and a separate 12volt source to provide full voltage to the motor. The factory wiring does not do that and it really contributes to slow windows and the motors going out
__________________
There has been real legnthy discussions on this at another board. The short story is...
It was propsed that the reason the motors constantly fail is from the ever increasing (with age) resistance of the wiring and switches in the power window circuit causing a high current draw.
The relays are wired in and wiring is run direct to the battery to power the windows - with the switches only being used to trip the relays.
I now own the second car that I have performed this mod on - and I can attest to it's undeniable success - as many others can. It woke up both of the tired motors on the 2000 SS I just bought.
There is even a company selling the parts needed to do (only the PS window) mod. It is purely a convenience, as the parts only require running about town a bit to collect.
I would highly recommend it to anyone tired of changing out window motors. The hassle isn't necessarily changing the motors, but this way you don't need to worry about them s-l-o-w-i-n-g down and driving you nuts before they fail.
This is a fix for what really seems to be a GM design shortcoming. Its not a workaround.
It still isn't a breeze by any means, but imagine doing it without that guide...
Anyway, my experience was much better than yours with my first one, but it still took me awhile to finish. I think I'm the king of taking breaks. Also, I had no problems drilling, as I was rolling the titanium drill bits (no breaks here). As stated earlier, now that you've drilled the holes, and done away with the rivets (as you bolt in the new motor), the next replacement will be much easier. The first one always sucks.
Even though your experience was kinda rough, just think of the money you saved over taking it to a shop. That should help a little. Maybe?
