my new T/A squeaks and clutch grabs too soon
Old 01-27-2008, 10:39 AM
MANbearPIG11's Avatar
Default my new T/A squeaks and clutch grabs too soon
i just bought my 98 t/a yesterday and for some reason it almost seems like the water pump is squeaking every now and then, it doesnt do it all the time, just randomly. also the clutch in it grabs right away, is there any way to adjust it?
Old 01-27-2008, 11:02 AM
ae13291's Avatar
ok if the clutch grabs right away, change your clutch fluid! at least flush out whats in your reservoir
Old 01-27-2008, 04:39 PM
ill try that out, anyone know anything about the ater pump????
Old 01-27-2008, 04:42 PM
Tudds's Avatar
how many miles are on it? it probably has an adjustable master installed
Im sure you'll get used to driving it, it is a new car to you
Old 01-27-2008, 04:50 PM
ae13291's Avatar
the same thing happened when i got my car! i remember the first day when i tried to shift at high rpm from 1st to 2nd and the tranny was just grinding, and the clutch was grabbing right off the floor! i took a look at the clutch fluid and it was the nastiest thing i ever seen! it looked like motor oil thats been in an angine for 20,000 miles!! so just clean the reservoir foe now until you get to flushing it completely form the bleeder screw! i dought you have an upgraded master, but i can be wrong! so just check the fluid for now
Old 01-27-2008, 05:17 PM
Tudds's Avatar
checking the fluid is the easiest anyways
Old 01-27-2008, 09:56 PM
the car only has 60000 miles on it, im going to take it in tomarrow, i have an auto class where i have access to a lift. ill do a complete flush of all the systems and check the belt as well as the water pump. does anyone know if these are bad on the ls1's? my buddy has a 2000 camaro and his is doing the same thing? its just anoying as hell driving down the road with this little squeak, anyone know? thanks guys for the help
Old 01-27-2008, 09:59 PM
Tudds's Avatar
98s are known to have faulty pulleys for the tensioner or the idler, I forget which one. I'm leaning towards tensioner. 97-98 only though
Old 01-27-2008, 10:42 PM
ae13291's Avatar
o yea lol u have the 98, so ur water pump is different! or could be the idler to so get that checked!
Old 01-28-2008, 02:58 PM
i got the clutch problem resolved, the fluid was jet black, i sucked most of it out and put new fluid in, does anyone know weather its the idler or the water pump?
Old 01-28-2008, 07:26 PM
ae13291's Avatar
remove your belt and spin the pulleys
