car starts but dies
car starts but dies
Alright its a 98 z28 camaro and when I went to start it yesterday it wouldn't stay running car starts up runs for a sec then craps out and when u try to give it gas the car dies I thought it was the fuel pump but u can hear it come on this started happening like 2 months ago had to rhide the gas and the brake to keep it running when I stopped. any ideas??
read this it might be of some help to you, its worth a try, and its free.
https://ls1tech.com/forums/showthrea...=838670&page=2
damn my car just started this wierd thing tonight after work i had to heal toe it in town but once i was one the highway it was perfect and after an hour on the highway i came into town and it tries to die again so more heal toe til i got home now the car is on the charger cause i was not sure if it was the battery but when i tested voltage it was fine so now i dont know what to do i have to drive it to work and am hoping mine just fixes its self just like that but i dont have that kind of luck
Fenili, do you have a fuel pressure checker? If not i would get one they are only about 45 bucks. Worth every penny to find out if it is a fuel pump or filter problem. My car did the same thing recently. I was idling it in the garage doing other work on my car and i let it run out of gas. After putting more in the symptoms were the same as you describe. Put a pressure tester on it and although the fuel pump sounded fine, it was only putting out a little less than 20 psi. Way less than the 58-60 psi needed on these engines.
well i got home and parked my car in the garage and had the charger on it for a few hours it did not even reach full yet and i thought what the hell i will try to start it and see if it idles or not and so i started it and was idling and running like nothing was ever wrong with it now that lets me know that i have something drawing power when it is parked so i will test a few things and it should be good as new. i hope your hunt goes just as easy
