Asr Off, Brakes, Abs Inop
Ok so when I start the car up the only light that's on is the SES light. After i drive a few miles, the ASR OFF, BRAKES, and ABS INOP lights come on. Also, the little light on the ASR switch goes off. Anyone have any idea?
If you search you'll find drawn out threads on this; short version, either you changed your wheels or tires and the rears are taller than the fronts, or you have a speed sensor that has gone out. If it's the first option, you're screwed. You can either pull the abs fuse and learn to drive without it, purchase an abs delete kit, or try to ignore it and wreck the car, as several others have done.
If it's the second option, get the abs code read and replace the sensor!
Doug
I just bought mine last week and it is doing this intermittently. I noticed there are different brand tires on the rear but they are the same size as the fronts. The rear end was making noise and I replaced it with a complete used rear end, so the two rear speed sensors are different. I'm planning to pull the front wheels off this weekend and do the brakes and check the speed sensors. I guess I need to check the dimensions of the tires and see if they are the same front to rear.How much difference can there be without causing a problem?
my lights come on sometimes right when i turn the key on and sometimes after i drive for a while. there are days that they never come on and other times they just blink on and off a few times. any ideas
