strange vibration at 65+
sup guys im getting a strange vibration past 65mph and it gets worse the faster i go but when i get on the breaks it goes away i feel it through my *** and a little through the shift **** i also just finished getting the rear end rebuild after throwing a pinion bearing any clues
have you checked to see if your tires are balanced and proper air psi??? start small before going too far in dept. my weights fell off my rear tire the other day and i fell into the same problem
i would get your driveshaft balanced. i bet thats what it is. i know from experience. and it doesnt cost much to get a shop to check it, maybe $30-$50. and i just had be rear end rebuilt and the pinion started leaking, the driveshaft caused that. good luck man. let us know what it is.
