So is it bad to have...
...a gas smell every time I change my oil? When I do a search most say its bad but my car runs like a champ. It's pretty strong every time I drain it. Whats the deal?
Internet Mechanic
If your oil has a gas smell your getting fuel wash down the cyl. It can hurt the motor badly. It breaks down the viscocity of the oil and bearings take a beating.
If you have the oil take your fingers and rub some of it between them, then compare to fresh oil out of the bottle. They should be a big diff is slickness.
Get that hand held tune out of there and get the car on a dyno. ASAP!
^^ What he said. Sounds like your injectors are washing past the rings. Gonna be a big problem down the road. May have some bad rings already and loosing compression since the fuel is blowing past them into the oil.
OP it's not too hard except for that bastard #8. Just get a kit, uplug all plug wires, unplug the coil packs and pull the fuses for the injectors and fuel pump. Put in the compression tester and hold the car WOT for 4 strokes to get the compression stroke and read your gauge. All your PSI readings need to be within 70% of each other and watch to make sure you don't loose compression over time. You can check for ring wear by putting a little oil in there (makes rings seal a little better) and you'll see a good increase in psi pressure. Seems like around 180 readings are LS1 territory.
And Cvaught I'd check the tune if the injectors are properly sized they will spray down the cylinder too much and wash out the rings and get into the oil.
Thanks guys for all of your help. I am going to keep an eye on my situation.
