low voltage problem
low voltage problem
The other day my voltage gage started reading in the red almost. So i took the car, its a 95 z28, to advance auto and they checked everything and the battery was good and the charging system output was normal. It did say my starter amp draw is low with ok starter voltage. It said to check starter circuit for loose , worn or corroded wiring. What wires should i check.
