fuel pump and exhaust question
I looking to change the fuel pump but my exhaust will not come apart. I got a slp loudmouth that is clamped together. I took off the clamps but the two pieces of pipe are still pinched together. What should i do? I was thinking of cutting off the slp loudmouth and getting the Texas Speed Rumbler 3" for 249.99. Anyone have that exhaust with stock manifolds and Y-pipe? But back to the fuel pump. Does the entire sending unit on top of the tank need to be off to replace the fuel pump. The pump I was looking at was the one from Graneteli for about 130 bucks.
no problem, i cut the door on mine and i like having the security there knowing if my pump goes out, i can swap it in 10min
i didnt cut mine to replace a pump tho. i cut it to remove my EVAP charcoal canister on top of the tank to reduce weight so the door is there just incase my pump goes out sometime soon
didnt feel like spending hours cutting exhaust and dropping the tank either
If I had to do mine I think I would cut the hole--many new cars come with access. Here is a link to a "99 :
http://www.gonicd.com/intankinstall/...mpinstall.html
Autozone wants 400 bucks for the entire fuel pump assembly. That is crazy. Where can I go around Cleveland to just get the pump for like a 100 bucks. I can't be waiting for 5 days to get one ordered online.
