EGR Bypass ????
EGR Bypass ????
I am looking to purchase a set of Kooks Long Tubes for my '00 WS6. The factory manifolds are equpied with the EGR provison tubes. I was wanting to purchase a set of headers without the ugly egr tubes & was wondering if any of you guys have bypassed this egr system. What is involved, how to do it & does it throw codes or cause driveability problems. Thanks Guys
You can get a block off plate for the intake or get a ls6 intake and some more power. The ls6 doesn't have the hole in the intake. You will throw a code but you can tune it out hith HP tuner or ls1 edit. You can also remove the air pump and all its hoses with your header install. That will also need to be tuned out. This will make the engine bay look alot cleaner and clutter free.
ok, Im having a problem tunning EGR and Air thing out... I log into HP tuners and then I put off on the Air selinoid, but theres no ON/OFF on the EGR, but whats annoying is then I log out and back in, and the codes still show that I have the Air selinoid code, which means it didn't turn off yet... how can I save the fact that I did set it to off...?!
Thanks
Thanks
Im not sure if u can tune out those codes with a handheld. But i will tell u that what i did was sent my pcm to wait for me performance i think it cost like 50.00 and they send it back in a week all u have to do is send a list of your mods and what you want tuned out air,egr skip shift, etc
I don't know whther its considered a handheld or not, but its an HPtuners PRO, and it has an ON/OFF option inside... I switch them off, go out of the ON/OFF window but they are still there... :S
Ya def get rid of egr and air pump bull ****.....If you dont have the money you can use a 1/3/8 core plug from your auto parts store theres 2 kinda on u silicone in the other is a think black rubber piece with a stud in the midde and nut one top. put it in the egr spot and tighten it up till the plug wont slip out and my suggesttion is get another nut and put it on top of that one w some lock tight so they dont come off. Cause if they do the stud will drop down and go into your motor causing hell and blowing it up!!
True ls6 intakes dont have egr but his 00 does have egr they didnt start putting ls6s on them till 01 or maybe im wrong and a few of the late 00 did get the ls6 not sure though
