Ram air on a Firehawk
Old 09-18-2003, 06:46 PM
00hawk120's Avatar
Default Ram air on a Firehawk
Ok guys, I realize that the Firehawk hood dosnt flow air as well as the WS6 hood dose. my ? is would the free ram air mod (cutting out the bottom of the air box) help me out any. it looks to me like it would help me get more air, but I wanted to get some more ideas before I started cutting. give me your 2 cents on this.
Old 09-18-2003, 06:55 PM
H b K l U n A's Avatar
Default Re: Ram air on a Firehawk
either way you should do the free mods. My buddy on his Z28 did the free ram air mod then ran 2 hoses to connect to his bottom shield in the front (the plastic protector that hangs down). He said he can feel it better then the free ram air mod by itself cause it was actually forcing the air through the bottom more then before. I will try to get some pics.
Scott
Old 09-18-2003, 07:00 PM
WS6FirebirdTA00's Avatar
yes yes yes do it. i have a ws6 and i did this, man it made a good bit of difference. my car has no problem sucking in air. i could actually see the maf numbers on the computer change, not much but they did change. this will give your car that gulp of air it needs
Old 09-18-2003, 07:43 PM
Drew778's Avatar
You should get the Super Sucker Ram-Air (SSRA)it's very nice peice!!!
Old 09-18-2003, 09:19 PM
00hawk120's Avatar
who makes the SSRA, I dont think I have seen it. it was looking at the FTRA, but im trying to save money for a 12 bolt so the FREE mod sounds good right now
Old 09-18-2003, 10:38 PM
WS6 GreeN's Avatar
When u guys say the free mod, you talking about cutting away the piece right below the airbox below the filter?
Old 09-19-2003, 12:43 AM
Judd's Avatar
Hmmm, have you thought about de-baffeling the hood and sealing it to the airbox?
Old 09-19-2003, 10:30 AM
LS1Tech Sponsor
Slowhawk's Avatar
Thats the answer
I cut the baffles out and raised the box.Easy to do with a dremel
Old 09-19-2003, 11:40 AM
WILWAXU's Avatar
I've seen WS6 lower air box/radiator supports on Firehawks. I'd remove the baffles in the hood and add a WS6 lower air box.
Old 09-19-2003, 12:07 PM
Brandon_TA's Avatar
I Will agree. Free Ram Air mod, is a must in my book.
Old 09-19-2003, 12:08 PM
BIGBOS's Avatar
I did the free ram air to mine, didn't bother to raise the air box though, also ran an SLP lid, worked fine.....
Old 09-19-2003, 06:22 PM
Jpr5690's Avatar
ON MINE I DID THE SLP KIT WHERE YOU GET THE DUCT THAT GOES IN PLACE OF THE FREE RAM AIR MOD ITS BASCIALLY THE SAME THING EXCEPT THE SLP MOD HASA DUCT THAT ALLOWS AIR TO ENTER FROM LOWER DOWN THUS YOU GET COOLER AIR INSTEAD OF WAHTS FLOWING OUT OF YOUR RADIATOR. THE PART WAS CHEEP AND ID RECCOMEND IT TO ANYONE, HELL EVEN WHEN I GET MY RAM AIR HOOD ILL LEAVE IT SETUP HOW IT IS NOW PROABLE. BUT ILL REMOVE THE PIECE OF INULATION THAT SLP SUPPLIES TO BLOCK OFF THE ORIGNAL AIR ENTREANCE.
Old 09-26-2003, 07:20 PM
ss1le02's Avatar
www.austinperformanceinc.com
Old 09-28-2003, 07:02 AM
02RedHawk's Avatar
The WS6 Lower-Airbox doesn't fit on Firehawks that use the SLP/Donaldson OEM lid, FYI....
Old 09-28-2003, 10:21 AM
B-MAN's Avatar
free mods are a plus(do it)
Old 09-28-2003, 07:15 PM
WILWAXU's Avatar
Will when used with a regular lid. Didn't realize the batwing was that much taller.
