Jet Hot coated header guys come in...
How does the coating hold up after a couple of years and do they keep the engine compartment from heating up too much...Thanks
well mine have been on for 2 years and look the same as when I installed them. No problems inside the engine bay that I have seen. Only issue i had was a wire that kept getting to close to the collector, a zip tie fixed that though lol.
One last question..do you feel that your engine compartment heated up more than when you had the stock exhaust manifolds?
My concern is the added engine heat from long tubes going into late rounds in bracket racing...
https://ls1tech.com/forums/drag-raci...ghlight=passes
