Install List check
Old 01-10-2009, 04:16 PM
vettett15's Avatar
Default Install List check
Hey guys,
I am going to be installing a bunch of parts on my 98 T/A next weekend and I want to make sure I have everything so there are no surprises.
1. Bryun Speed
lower control arms
2. texas speed
gaskets/head bolts
lifters
rod bolts
3. ebay
valve covers
coming with gaskets and hardware
4. ebay
oil pump
5. heads
have head/exhaust/intake gaskets and bolts
I am going to measure which pushrods I need and then pick them up local
6. cam
7. oil
8. oil filter
9. oil pan gasket
10. injectors
should plug right in
11. coil brackets
not sure if i have the hardware for these, I am going from a perimeter to center setup
12. UDP
For this it sounds like the way to do it is get a longer bolt from home depot or something to help put the new pulley on.
I don't have the belts for this, anyone know the part #'s?
Old 01-10-2009, 05:02 PM
69_YENKO's Avatar
Originally Posted by vettett15
Hey guys,
1. Bryun Speed
lower control arms
2. texas speed
gaskets/head bolts
lifters
rod bolts
3. ebay
valve covers
4. ebay
oil pump
5. heads
6. cam
7. oil
8. oil filter
9. oil pan gasket
10. injectors
11. coil brackets
12. UDP
For an 25% UD ASP pulley these are the belt sizes they recommend not sure what you have but it SHOULD be the same??
Accessory Belt = 760K6
A/C Belt = 378K4
for install I went to a local bolt/industral store and bought a couple nuts, washers & a piece of all thread with the same thread pitch as the metric crank bolt and made my own install tool.
figure on a new set of spark plugs and dont forget anti-freeze. Im assuming the heads are setup and wont need new springs not sure what else i'll keep looking at it and update if i see anything else.
Is there a reason you are going to pull the pan and install new rod bolts?
Old 01-10-2009, 10:45 PM
vettett15's Avatar
Thanks for the belt #'s, I need to pick up some plugs too.
For the rod bolts I just wanted that extra security, not have to worry about the 98 bolts destroying my motor when I rev to 6500+. I will have a good amount of help and will be using air tools so I don't think the job will be too hard, but we shall see. Thanks again,
Pete
Old 01-10-2009, 10:56 PM
9000th01ss's Avatar
1998 rod bolts?
They seem stronger than the rods.
This came out of a stock '98 A4 TA, it was still running.
A 1/2" part at the bottom of the cylinder was deburred, it was honed, and a used one put in it's place. All done in the car.
Old 01-11-2009, 05:00 PM
vettett15's Avatar
hey 9000,
that looks absolutely horrible, but I don't think it is representative of the normal ls1 bottom end failure. I've had friends, 2 to be exact, that have had spun bearings from what I believe to be over reving their engine.
I understand it isn't the easiest thing to do but I believe it is pretty cheap, since I'm doing all the labor, insurance. I spoke with a couple of performance shops who are familiar with these cars and have installed the arp rod bolts by dropping the pan and haven't had problems.
