Full 85mm setup
Old 01-22-2009, 02:33 PM
Alt
Alt's Avatar
Default Full 85mm setup
Here is a topic for discuttion that I'll throw out there as someone may already know, I can't get a whole lot out of the search today.
Pro's/Cons to a full 85mm setup - Lid, MAF, TB, and hogged out intake snout to 85mm
Compared to 85mm Lid, MAF, and either stock TB or stock TB opening
As pertaining to a bolt-on motor, any information regarding velocity vs quantity of air, etc..
Here we go I'll add in some more, given a perfect volumetric efficiency a 350ci motor can only move 608cfm@6000rpm and 658cfm@6500rpm, does anyone know the flow rate on the stock throttlebody?
Old 01-22-2009, 02:53 PM
LS6427's Avatar
I'm no expert, but how can this one not make more power. Considering how restrictive any stock parts are on the LSx engines. You're bolt-on stock cube engine should love it.
85mm all the way through, nice to have no weak link.
Old 01-22-2009, 03:23 PM
Lopoetve's Avatar
gonna need a retune for the maf, I expect. or so I've been told.
Old 01-22-2009, 03:33 PM
Alt
Alt's Avatar
Yeah I'm on the tune, my sig hp is self tuned.
Back to the original topic; Bernoulli's Principles on fluids, how does that play into the above topic.
Old 01-22-2009, 04:24 PM
01Z0H6's Avatar
I'll let you know... I am stepping up next week to a FAST 90/90,FT85mm Lid, Z06 MAF(Delphi) to compliment my H/C... We'll let ya know..
Old 01-22-2009, 06:35 PM
dirt track racer 81's Avatar
i have a 85/85 pro-prod intake and tb if interested
Old 01-23-2009, 05:10 AM
Alt
Alt's Avatar
No help
Again no help
Old 01-23-2009, 10:46 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
Well, I will give a very general answer. The numbers you quoted for airflow are assuing 100% VE. These engines fall in the 1.08-1.12 range as far as VE goes. So, if you take your 658*1.1= 723.8.
The stock LS1 throttle body flows 880cfm @ 28" of water. A good ported one flows 930ish. You would see roughly 5hp when swapping between these throttle bodies. I am not sure what the flow numbers are on a 85mm, but I do know they will make about 5-7hp at the wheels.
Now, it really doesn't make sense, but it does make more power. I would guess you could pick up around 10rwhp if you switched and did all of the changes.
Hope this helps.
Old 01-23-2009, 03:48 PM
Alt
Alt's Avatar
Finally some answers, would there be a difference between keeping the stock TB and porting it vs upgrading
