How to find an exhaust leak?
Old 02-10-2009, 10:34 PM
Eric1987's Avatar
Default How to find an exhaust leak?
I just recently installed some headers and I hear some sort of wind or fast exhaust which feels like its almost directly under my feet. Could that be an exhaust leak? I dont feel lack of power. I put in some LTs with no cats and an ORY.
Old 02-10-2009, 11:04 PM
conan's Avatar
Usually you can see black exhaust around the joint that is leaking.
Old 02-10-2009, 11:17 PM
Eric1987's Avatar
I've only had it for a couple weeks. Would it still show up?
Old 02-10-2009, 11:19 PM
R1ch's Avatar
What kind of exhaust clamps do you have on it?
If you have those stupid U's with the two nuts they give you with the headers I can almost guarantee they're leaking.
Old 02-10-2009, 11:21 PM
johnLs1camaro's Avatar
^ yeah i agree, i switched to the band clamps and really liked them!
Old 02-10-2009, 11:26 PM
ItsNotStock's Avatar
Before your exhaust pipes are warm (important) spray some soapy water around the joints. If you have a leak they it will show with bubbles.
indirocz28's Avatar
Yeah - those clamps blow..
Also- If you are looking for a leak you can close off the tailpipes and that will cause backpressure and it will cause the exhaust to flow out of the leak. so like hold a board over the pipe or something and have someone listen and shine a flashlight on where you think its leaking from..
I also dont use gaskets with my headers, i just put Copper RTV sealent on the header flanges and then bolt them up- dont have them leak...
Old 02-10-2009, 11:43 PM
Eric1987's Avatar
I have the U clamps but I tightened them real good. I'll try that covering the exhaust thing. Would I feel a loss in power? I definitely felt an increase in power.
Old 02-10-2009, 11:47 PM
indirocz28's Avatar
probably not, but depending on how close it is to the o2 sensor you could notice a decrease in fuel mileage..
with an exhaust leak before or close after the o2 sensor it allows oxygen to be sucked through the leak into the exhaust stream between pulses twards the o2 sensor skewing the readings to the computer thinking that it is actually lean rather than stoichiometric.
Old 02-11-2009, 12:10 AM
twitchtwice's Avatar
what me and my dad did on his was put rags in the exhaust and stick a air compressor hose in there and walked around underneath the car until we felt the air coming out. but we have a lift though.
Old 02-11-2009, 12:22 AM
Eric1987's Avatar
Would be great if I had access to a lift...I did mix up the O2 sensors though. I put the cat O2s in the headers. The header O2s are just sitting out there. I just got my O2 extensions. Would that even make a difference?
Old 02-11-2009, 12:27 AM
conan's Avatar
Get rid of the U style clams for some band clams. Hope you didn't crush the pipes so they wont slide apart inthe future.
Old 02-11-2009, 12:40 AM
Eric1987's Avatar
Where can I get the band clamps? And why are the U clamps so bad?
Old 02-11-2009, 09:21 AM
conan's Avatar
Got mine from sdpc when I got my kooks. http://www.sdpc2000.com/cart.asp?act...tart&catid=873
Call them and ask them for 3'' stainless exhaust band clamps. The reason I and many others dont like them is they crush the exhaust pipe, and if you tare your car apart as much as I do getting the exhaust apart after its been crushed is a bitch. The band type wrap around the whole pipe and join the two.
Old 02-11-2009, 10:30 AM
z28voodoo's Avatar
U-Clamps are basically pinching the two pipes together and WILL leave a gap for exhaust gas to escape. Even if you tighten them super tight, you are still just pinching the pipe and will (as stated above) be a pain to take apart in the future.
Summit, WS6 Store, Speed Inc., and I believe NAPA stores sell them.
Old 02-11-2009, 12:48 PM
SS1875's Avatar
You might also see some black moisture runs on the pipes. Band clamps are much better as they basically mold themselves to the pipe contour for increased sealing area.
Old 02-11-2009, 12:51 PM
Eric1987's Avatar
Would it matter about how I switched the O2 sensor locations?
Old 02-11-2009, 12:54 PM
Eric1987's Avatar
And are they your typical clamps that go on hoses or on your bellow that goes to your intake? Those? Or something else?
Old 02-11-2009, 03:35 PM
you can get the band clamps at any autoparts store, they cost a little more then u clamps but are worth it! they are like a then flexible sheet of metal that is 3 inches long and it raps around the exhaust and tights with 2 bolts.
Old 02-11-2009, 05:20 PM
TheSilverOne's Avatar
NAPA sells band clamps. Auto Zone and Advance Auto Parts in my area do not sell them.
Quick Reply: How to find an exhaust leak?
