Need help!!!!!
Old 02-13-2009, 06:01 PM
posz28's Avatar
Default Need help!!!!!
Ok, so my MAP Sensor is bad. Well, I take off my lid, throttle body, and unbolt my intake manifold. I know that the MAP sensor is behind the intake manifold. How do I get the manifold out so I can get to the sensor?!?
Old 02-13-2009, 06:06 PM
SS1875's Avatar
Here you go...obviously omit the swap part.
http://ls1howto.com/index.php?article=5
Old 02-13-2009, 06:08 PM
ski23's Avatar
Actually nice to have another set of hands. Need to hold the four back bolts up so you can wiggle the intake up and forward.
Old 02-13-2009, 06:10 PM
posz28's Avatar
^^^Thanks..its comman sense...lol.
Old 02-13-2009, 06:11 PM
posz28's Avatar
Yes sir, thats true. Camaros are a pain in tha butt to work with...lol.
Old 02-13-2009, 06:13 PM
Dirtybird99's Avatar
I should have posted up before i started mine. Would have saved me about 80 bucks
Old 02-13-2009, 07:12 PM
SS1875's Avatar
A trick to use is (4 )1 1/2" pieces of 3/8 hose(slit on one side)......loosen the bolts to where you can pull them up and place the hose pieces under the head of the bolt.....holds them up out of the threads.
Old 02-13-2009, 10:10 PM
DaddySS's Avatar
I just strung rubber bands between the last two pairs the first time, the second time I bought the little green spring clamps from Home Depot and clamped one on each bolt in the back.
