Best/ Cheapest place to buy 85mm maf
You could just port your stock 75mm housing. the only thing you'd be out is time...and the cost of the die grinder, the carbide bits, the air compressor, tubing, etc. I've already got these things so it was a bit easier. eBay dumdumdum!!
I am so glad I read this thread. I was going to purchase the slp one from Fast toyz. Problem is how do you guys know which one on e__y is the right one for the car? I plan on getting the fast toyz lid and there ram air setup. If i can get a Gm one that would be great. Please point me in the right direction or maybe you can tell me which vehicle I should look this up under. Thanks Chris
You DO NOT need an 85mm lid or bellows. The stock bellows fits right on and the ID of an 85mm maf is the same ID of an airlid. You will need a boot to slide over the outside of your lid and over the outside of the maf.
Oh BTW, mine is an 85mm SLP and it runs great. I picked it up used with the adapter for 45 bucks
