where to weld fitting to pressure check exhaust?
Old 03-08-2009, 06:24 PM
TJ
TJ's Avatar
Default where to weld fitting to pressure check exhaust?
collector
one side of the y pipe
backside of the y pipe
before the muffler?
Old 03-08-2009, 08:22 PM
SweetS10V8's Avatar
Ive never done it, but I have always understood it to be one in front of and one behind the muffler since it is your restriction.
Old 03-09-2009, 07:54 PM
DaddySS's Avatar
do you mean to check backpressure?
Old 03-09-2009, 09:30 PM
TJ
TJ's Avatar
yes.
thank you.
Old 03-09-2009, 09:41 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
Originally Posted by TJ
yes.
thank you.
WHY
Old 03-09-2009, 10:18 PM
jsteele90's Avatar
why would you want to do this?
Old 03-10-2009, 02:10 AM
SweetS10V8's Avatar
To see how much of a flow restriction your muffler is causing.
Old 03-10-2009, 05:48 PM
TJ
TJ's Avatar
thats the idea.
the exhaust is easy to drop, but a pain to get lined back up, so it makes it hard to do it at the track.
trying to decide if i want to keep what i have or go duals.
id at least like to know if its hindering me or not.
Old 03-11-2009, 02:42 AM
DaddySS's Avatar
The back side of the y would give you the best reading, but if you want to take the readings again after you would want to take it from the collectors.
BTW, there are tools that mount in the AIR pump or O2 fittings, which might be the easiest approach.
Old 03-11-2009, 05:35 PM
TJ
TJ's Avatar
well how bout that.
glad i posted this thread. im going to search now, but do you have a link to such adapter?
i can pop it right in my 02 bung.
Old 03-11-2009, 06:49 PM
DaddySS's Avatar
http://www.thefind.com/cars/info-exh...ressure-sensor
Old 03-11-2009, 06:50 PM
Red99TA's Avatar
I've never heard of this. How can it work since there's still a flowpath through the motor past the rings or past the exhaust valves that are open and out the throttlebody. I mean the TB will be shut but there's still flow through the hole in it. I would think you need the flowpath up the exhaust towards the motor sealed to make it more accurate.
edit - nevermind, this is probably done with the motor running right?
Old 03-11-2009, 06:55 PM
DaddySS's Avatar
You basically want to run the engine at wot up to your target RPM. I believe the target is 7PSI or less and for every 1 PSI above that figure about 5hp loss.
