View Poll Results: TDs vs an ORY w/Dual Cutouts - Which sounds better?
True Duals
20
50.00%
ORY w/Dual Cutouts
20
50.00%
Voters: 40. You may not vote on this poll
TDs vs ORY w/Dual Cutouts
Obviously I'm trying to decide which to do here. The car has Stock headers, an ORY, an LM1 right now. Here are the 2 Options I'm debating doing:
- LTs, TSP TD package (most likely dumped)
---or---
- Stock headers, ORY, Dual cutouts on the Y, quiet Catback (for around the popo)
I'm trying to make the car louder and sound as mean as possible. If I get some performance gains, I wouldn't mind it. I have a feeling I know what the consensus is going to be but I figured I'd ask just to make sure. I've already exhausted all of the clips on LS1sounds.com. Most of those cars are cammed so it doesn't give a true hint at what my car might sound like.
Thanks for anyone who submits thoughts.
---or---
if you are worried about cops, and want to have a quiet car sometimes, go with a ORY pipe and electric cutout/cutouts. This way, you can go from loud to quiet with a flip of the switch. I'm going to set up something similiar soon. I just can't get rid of my Corsa exhaust lol
This is an easy one. Get the long tubes, an H pipe, two mufflers (Borla XR-1, Flowmaster single chambers, Hooker Aerochambers, etc, and dump them near the axle
I run a setup similar to this on mine (MAC mids, two Flowtech Raptors, H pipe dumped on the passenger side at the rear axle) and I don't get any annoying drone on the highway/interstate, and that's with a 3 speed. Duals should have been the first thing I did to mine, I can't stand Y pipe setups
get the dual cutouts, you can't lose its the best of both worlds and you get to choose when you want either.
On a side note, if you're this concerned about flow when it comes to true duals or dual cutouts nothing will help you more then LT's. Maybe you're not that concerned about flow but if thats a concern at all spend the 400$ and get some Pacesetter LT's they will give you a MUCH better sound too.
It's so hard to decide! This will be the 4th setup since I've had the car... hopefully the last.
On a side note, I ran .3 and 3 MPH faster once I swapped to the catback. I'm not saying the swap alone was worth that much time, but weather conditions were almost identical. The only difference on the car was the front swaybar was removed and there was about 1/4 tank less gas on the faster run.
I see you're in MD too, there are cops all over germantown where I'm at. I'd say get the cutouts so you can control the volume when cops are around and open it up when they're not.
It's the damn cops in Rockville. I live in Olney (I'm sure you know where it is since it's in the same county). They pull me over for everything in Rockville, and I don't even speed there!
The poll was for which sounds better, and I think if you just listened to the two setups, most true duals are gonna sound better! My sig will tell you Im a little biased I just picked up the duals today, but in Indiana cops dont really car about anything, I ran with my cutout open always on my current setup and never was bothered...I think you are gonna have some clearance issues with the dual cutouts unless you get the low profile oval ones and this is gonna be much more expensive route then the duals.
Either way you go though get some longtubes
ive got dual cutouts right now, and am really considering going to duals. main reason is im just tired of the cutouts. they sounded awesome and everything but they leak and come loose and flutter all the time now. Ive had them for a little more than two years, so i cnat complain too much, but i would really enjoy an h-pipe with single chamber flows...
i am going tommorow to get a price quote on a dumped setup like i described above, and if its around the saem price as the electric cutouts im gonna need to replace, i may just go that route
this isn`t one of your optoins but how about 3 inch into a flow master merge pipe with 4in to a cut out with 3in over the axle to a quiet muffler(i`m thnking magna flow or slp dual dual for mine) patric g used in his "recipy for 500 hp" and a friend of mine has it and it seems to make nice power and has decent ground clearence. if not that the tsp true duals just looks sick
im runnin 1 7/8 kooks, td dynomax bullets with an ORX and its all 3in pipe mandrel bent and dumped. i love it. the best is when you pull up at stop lights and old women role their windows up cause they cant stand it!
