Installed Pacesetters and TSP Cat Y - Have a problem
Old 03-14-2009, 02:41 PM
Moderator
nhra-trans-am's Avatar
Default Installed Pacesetters and TSP Cat Y - Have a problem
After installing my Pacesetter headers and Texas Speed Catted Y pipe, my buddy noticed that the Y pipe is pretty close to the brake lines that go along on the driver side. We really didn't see an easy way to get more room between the Y and the brake lines. Is this the way that the Y is designed to be or does anyone have suggestions for trying to get more room between the Y and brake lines? Thanks.
Old 03-14-2009, 07:56 PM
Sbertolone's Avatar
if your concerned about the heat wrap the pipe and put some heat shielding wrap on the brake lines.
but i wouldnt be worried about it, brake temps at the caliper far exceed any radiant heat from the exhaust.
Old 03-16-2009, 01:22 AM
Moderator
Ok, so it really shouldn't be a problem? They are not touching, but they are close.
Old 03-16-2009, 01:49 AM
Soul TKR's Avatar
fuel line = problem
brake line = not so much
Old 03-16-2009, 09:05 AM
LS1Zedder's Avatar
If you look at the bracket where the lines are it is possible to "flip" them up slightly. Thats what everyone does. I've had mine on for 4+ years and never had a problem.
Old 03-16-2009, 09:16 AM
Jon@Texas-Speed's Avatar
Like the previous posts says, flip the bracket on the brake/fuel lines and that will move them up to give you some more room.
Jon
Old 03-16-2009, 10:00 PM
syclone74's Avatar
I have this same problem with my install, guess i will flip the brackets and see what happens.
Old 03-18-2009, 12:43 PM
Moderator
Thanks guys. I will try that.
