Cutout Question
Old 03-17-2009, 10:51 PM
Greekey's Avatar
Default Cutout Question
Im a little confused here. Do most of you guys who run cutouts, run dual cutouts or a single cutout?
Old 03-17-2009, 10:54 PM
RoDan's Avatar
Single, right under the rear seat (assuming you have stock exhaust for a catback). I run dual cutouts on the Z28 right after the header collectors so I can run open headers for racing. For street use, one right under the rear seat.
Old 03-17-2009, 11:01 PM
Joker98's Avatar
I run mine under the passenger back seat foot-well..You can run two of them on your Y-Pipe but pending on your mods, I think its a bit overkill!! Not enough for you to realize where you put it unless your makin some serious power!
Old 03-17-2009, 11:05 PM
Greekey's Avatar
Thanks guys...I just wanted to make sure I was gonna regret only puttin one...I just wanted to know if most people ran 2. So this is the correct location?
Old 03-17-2009, 11:07 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Yup....
Old 03-17-2009, 11:17 PM
LS6427's Avatar
Do you think it'll make much of a difference to go dual cut-outs right after each collector..........compared to just one 4" cut-out after the Flowmaster merge, before it goes over the axle to the muffler?
Its a big build, 454ci, its gonna make well over 600 RWHP.
One cut-out if fine with me, unless it'll make a big difference with duals.
Old 03-17-2009, 11:20 PM
NHRAMAN's Avatar
Exclamation
If ground clearance is not an issue, I would certainly have 2 on mine.
Old 03-17-2009, 11:31 PM
LS6427's Avatar
But will it actually make a difference that is noticable? My hard runs where the cut-out(s) would be open are gonna either be on a 150 shot or a 300 shot. And of course alot of playing on motor.
So if its not gonna do much, no need for duals.
Old 03-17-2009, 11:34 PM
Greekey's Avatar
Old 03-18-2009, 12:04 AM
00cls1camaross's Avatar
in the exhaust system
