FM Merge bullet Sound clip
http://www.youtube.com/watch?v=zkNhkK3Q7x8
Sound clip for everyone.
Shows that with a proper merge you WILL NOT have rasp. Good viewing guys
I'm doing a full exhaust. 1 7/8' stepped to 2" LT's, FM merge 3' in and 4" out, back to a Magnaflow muffler but I'll have either one 4" cut-out after the FM or dual cut-outs right after each collector.
So a 600+ RWHP 454ci engine with a cam in the 260's would pretty much be a cop magnet, right?
Well, I have ~500 RWHP now with my 427ci. Grotyohann 1 7/8" LT's, no cats, into a merge and 3" all the way back to my Magnaflow. It sounds friggin great.
I was just looking into other systems for when my 454ci is done but after a long time now I see its probably the best system. Add a cut-out after the merge when I get the new system with the 4" merge exit back to the Magna and I'll be all set I guess.
Yours sounded so quite in the clip, I guess its deceiving in the clip though. Thats what mine will be like with the cut-out open then with the new engine.
Torched I have heard your car and its amazing that you still have rasp... Sounds mean as all hell... but still some rasp. Have you heard a similar car with gmmg? Did it have rasp?
If i get the rest of the little things im working on wrapped up tomorrow ill get a flyby.
Here is another vid, you can hear the rasp. I will be ordering a PowerPack bullet to put in the I pipe to help eliminate the rasp
My buddies 02 Z (stock internal) had same exhasut as me but with cats and had no rasp.
I ment basically changing the cat back piping. Not removing it all together.
But if the powerpack takes care of business no reason not 2.
Does the clip seem quiet on your comp torched? Its pretty loud in person.
When i listened to it on the VC itself I said "It's not that loud..."
Then when we hooked it up to the comp with mini subwoofers I actually got to hear it... Ya its loud...
only reason you dont have rasp is its dumped
i build exhaust for f bodies all the time and it dont matter if its true duals with x or h, ory with crappy merge or the flowmaster merge
