Underdrive pulley on A4
Old 03-19-2009, 06:58 PM
mook99ta's Avatar
Default Underdrive pulley on A4
Well I took the advice of members and got an 8" pulley puller to remove my stock one. There is no way in hell that and 8" puller is going to fit with the radiator and fans on there, not to mention the claws don't even fit inside of the pulley. Maybe its because it a cheap harbor frieght one but needless to say it doesn't fit. What size puller did you guys use to pull you crank pulley an an A4?
Old 03-19-2009, 09:19 PM
01ssreda4's Avatar
the cheap ones will work but 8 inch is way too big, ask me how i know get the 5 inch, it works perfect.
Old 03-19-2009, 10:28 PM
jrpimp00's Avatar
I used a 5 inch and works great, got it for 6 bucks.
Old 03-19-2009, 10:38 PM
Strahley's Avatar
Do you auto guys use an alternator overdrive pulley along with the new underdrive pulley?
Old 03-19-2009, 10:46 PM
Trunion King
bene's Avatar
I'm not using one.
Old 03-19-2009, 10:57 PM
devildog's Avatar
not trying to steal your thread but what are the advantages of a UD pully...power wise? Also what belt would you use?
Old 03-19-2009, 11:25 PM
01ssreda4's Avatar
Originally Posted by bene
I'm not using one.
me neither but my idle is higher w an aftermarket cam.
Old 03-20-2009, 01:38 AM
IRACE2's Avatar
I use an overdrive for the alternator. It comes in handy in the summertime when the air conditioner is on high at stoplights.
Old 03-20-2009, 03:12 PM
mook99ta's Avatar
where did you get a 5in? All I can find is 6 or 4 at all the auto stores here.
Old 03-21-2009, 09:59 AM
01ssreda4's Avatar
got mine at harbor freight.
Old 03-21-2009, 12:12 PM
MikeG's Avatar
I've never used an OD alt pulley and have had no charging issues.
Old 03-21-2009, 02:20 PM
DaveX's Avatar
I don't use an overdrive on the alternator. It's not charging very well at idle but it hasn't been a problem. I make it a point not to get stuck in stop and go traffic when possible though, my car isn't a dd.
