NGK T6 Plugs Or TR55 Plugs?
What plug should i run for my application? I am currently running TR6 plugs, but is that too cold?
I was reading on NGKs website that the TR55s are for a NA motor. And the TR6s plugs are for high compression motors or N20....
I am currently running the TR6s plugs in my CAM ONLY stock H/I car. I am making 415/378 at the rear.
Now in the spring i am adding 42# injectors, 85mm Lid, 85mm Maf and an E-CutOut.
Should i be running the TR55s or TR6 plugs? What should they be gapped?
I have been using TR6 plugs, i am cam only and NA.. That is what my tuner told me to use. So i have been reading and been getting mixed reviews...
I'd just stick with the TR6s. I run them on mine when I'm NA (obviously not spraying every moment that engine is running), and I don't notice it running any different than with the TR55s that were in here before
If it matters or not, I have run stock pluggs, Denso's, TR55's, and now a few months with TR6 in my car. I have not noticed any diffrence other than slightly less detonation with the TR6's (but I also put in a 160' thermo at the same time). I will stay with the TR6's. I cant remember the gap, I think I set them to .40
Runing just a bunch of bolt on mods on the LS1...
Those two plugs are identical plugs, just gapped differently from the manufacturer.
Run the tr6 plugs they may not last as long but there a good plug and only $15.00 a set I,m spraying so I may gap mine a little diffrent. Mine are at .043 Thats what my tunner bluecat(phill) told me and they always worked great.
