Ticking noise with Jethot headers
Guys/Gals:
I have had my jethot headers on for about 3 weeks now. Just developed a loud ticking noise and does not seem to be a header leak.
NO I did not do the AIR Restrictor Plate MOD!!!
I know, I will do it.
Where are the AIR Check Valves located, since I may need to check them to see if they are burnt up?
I have the sheet metal and the 4 AIR gaskets for the restrictor plate mod, just have to find some time to do the install, but figured while I do that I might as well check the AIR check valves just in case they need replacing.
Thanks.
Rick
rickgrebner@comcast.net
Thanks.
Rick
to the top!
Need to know where the AIR Check Valves are located? Pics or instructions if possible.
Thanks.
Thanks.
Originally Posted by 98WS6
Guys/Gals:
Thanks.
Rick
Thanks.
Rick
The air check valves are the little black round barrel like jobbers threaded onto the air tube, just after the bend in the small pipe that was secured to the top of the header.
It is the little black thing just to the left of the master cylinder, and a mirror image on the passenger side.
Does that make any sence?
Is this it? See white square in your pic at bottom of post!!
I know this is probably a stupid question, but on the above picture of the red SS there is a tube in front of the intake but behind the throttle body.....What the hell is that?
I have never seen that before except on engines equipped with an NX system, so I thought it was something NX did since I know nothing about nitrous. But now I see it on this car so I am thinking maybe its the EGR which I have no expierence with. Just guessing.
how would i go about doing the A.I.R. plate restricter mod? and what are the benefits of it? will it set an SES??
thanks again
jimmy
PS. what are the odds that i can get the dealer to warranty the check valves?
thanks again
jimmy
Air mod.....?
Originally Posted by jimmy 2 Times
i did a search, and this is the only thread i got, also would you happen to have the part number for the check valves?
thanks again
jimmy
thanks again
jimmy
Once the car has ran for awhile it's fine. Once i kill it & start off again, i get that damn "flutter".........."tick" whatever you call it! Very annoying. I will fix it this weekend.
Any idea of what the "check valves" run?
Excellent post...... as i have been too lazy to track this as well!
Originally Posted by PewterY2KZ28
I am having the same prob. It seems worse on cold start up's.
No check valves,air tubes. No tick!?
Make sense? As i understand it, removing the air system will not throw a code, nor will it effect drivability.
Someone chime in please..............
the check valves are PN 12565503, about 39 bux shipped from gmpartsdirect.com
1 more question, if i get rid of the AIR system (from ls1camaro.net) will i need the valves? i already got rid of the cats?
thanks
jimmy
thanks
jimmy
Doesn't it only throw a code if you remove the pump? I was under the impression that if you kept the pump in the circuit the computer didn't know the difference. (yeah... I know it's loud as hell if it's still there and running)
