msd 6ls worth it or not?
the person the started the post most likely thought it was like the 6al. he most likely wanted to know if they needed extra spark for the coils like the original one did. id say that has to do with the coils. considering hptuners is just a little extra and does allot more than this box would do i would say its a waste of money. unless you can think of something that this box would do that was more helpful than a good tuning suite.
just as the title says. is the 6ls worth it? what all is needed to use it a special harness?
And to the original poster: yes, you'll need a harness if you're piggy-backing it to the factory PCM. Only when running it in stand-alone mode, do you not need the harness
Russ
its called making an assumption, since everytime someone asks about these they are asking because they are thinking of the 6als that provided extra spark for a better burn. i would bet that is why he asked about it. judging from his answer saying thanks for the advice that is why he asked. if that answer was not clear to you im sure someone can explain it to you, i cant i dont have the patience and crayons to draw you a picture.
