car idling fast
Old 05-10-2009, 02:56 PM
02cetransam's Avatar
Default car idling fast
My car idles fine at a cold start but after Im driving and a depress the clutch, the car will idle at about 1300 rpm and then go down after 2 or 3 seconds then it will idle normally. It almost always does this after Im driving and then I go to depress the clutch. It used to go right down to about 800 rpm as soon as I put the clutch in. Does anyone have an idea as to what may contribute to this lag? Thanks in advance!
Old 05-11-2009, 05:37 AM
teke184's Avatar
modded?
tuned?
could be an issue with your idle. try the idle reset procedure.
Old 05-11-2009, 11:07 AM
loyolacub68's Avatar
Is the clutch vacuum assisted? Sounds like a vacuum leak to me. Also try the advice above.
Old 05-11-2009, 11:44 AM
GR8GAME's Avatar
How do you do an idle reset?
Old 05-11-2009, 09:34 PM
how do u reset the idle? No, there arent any major mods and it never happened before I put it into storage. I appreciate any advice.
Old 05-12-2009, 06:43 AM
teke184's Avatar
pull the battery cable for a while....will clear the computer of all the "learned" values.
could also try just unplugging the TPS with the ignition on...let it sit for a minute then plug it back in.
then start it up and let it idle for a few minutes
Old 05-12-2009, 06:03 PM
alright, ill give it a try. Thanks!
Old 05-13-2009, 10:20 PM
senicalj4579's Avatar
yup sounds like a vacum leak somewhere. Or maybe a sensor. Is it throwing a code?
