ls6 intake vs bbk ssi intake
whats better a ls6 intake or the bbk ssi intake. i got the bbk intake but my tuner says to get the ls6 intake. any help what wrong with the bbk intake
if you can clean up the rough flashing in the runners, should help. only problem with that intake is the weight of it and the heat it will hold over long drives. still a nicer looking intake than the ls6.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
A friend has the BBK in his LS1 Blazer.....looks much nicer than even the FAST.....holds the heat more, as said above. I like the looks so much more....Keep it, unless your goal is high HP..then get a FAST.
