Who has the un-coated Pacesetters?
Who has the un-coated Pacesetters? How are they holding up? Does the paint burn off on startup, and then does the header start to rust immediately? How long have they been on your car, how do you like them, how do they look, etc?
Thanks, Shawn
Thanks, Shawn
A local guy had them and he said the paint came off and started to rust. He told me to at least coat them with something, he painted them with grill paint and had no problem after that.
I have the coated headers, but the painted Y pipe, I can already see paint chipping off of the Y. So I can see the painted ones not holding up as well. But all in all they are a beautiful set of headers and maybe some of the other header makers ( Hooker ) might start dropping their prices with what Pacesetter is charging.
I have a set of Pace Setters and on a tag it says to paint the headers with a high temperature paint. Do you need to strip off the factory paint before spraying on the high temp?
The Y pipe made by Pace Setter has a horrible collector. Is there another inexpensive Y pipe out there that flows better? Most others cost more than my headers cost.
The Pace Setter is just two pipes welded together. What a disaster!
LS1TECH Sponsor
dude get the coated headers...i got mine for $303 with shipping included so whats that 60 bucks more than the uncoated and they look great...also it helps keep underhood temps down, keep velocity up, and keep them from rusting nearly as quick. JMO but its not worth getting the uncoated.
lata
Bill
lata
Bill
lata
Bill
lata
Bill
foff where did you get your headers for $303 shipped? PM me, if its not a sponsor.
Originally Posted by WS6FirebirdTA00
i would like to know about the ypipe too.....i heard a lot of bad stuff about the collector, however its cheap so im sure if there is a pipe merger out there that flows great can be welded on cheap
If I can find the mandrel bent 3" tubing I just make fabricate my own.
so will that work with the stock collector at 3" ? should i get a larger pipe for the rest of the collector?
Dual 3" cutouts in the Y pipe right off the headers leading into the dual 3" x 3 1/2" Flowmaster collector then reducing back down to 3" to mate your existing exhaust. This would make a super track and street set up.
