How hard is it to replace motor mounts with longtubes installed?
Random question - I'm gonna install poly or solid mounts before I drop the longtubes in, but I'm also going to have the whole shebang welded up to fit right after they're in - if I have to replace the mounts in the future, how hard is it to get them with the longtubes still installed (since removing them will be extremely difficult at that time, obviously).
Just done it the other day. Be prepared to cut the crap out of your hands and pull off alot of accesories (ac comp., starter, alternator, etc.)... Just read the writeups they pretty much cover it all it will take some time and muscle trust me.
Don't weld all that crap up. Virtually nobody welds there stuff together. Band Clamps are where it's at. It's really hard with the headers in place to replace motor mounts. Even worse is if you had to drop the entire Header/Y combo as one piece cause it was welded to get to the mounts.
I'm going to replace the mounts now as well, but I'm thinking about things in the future, when they go bad again. I want this stuff to be high quality, which means custom fitting and welding - as it is right now, the muffler hangs crooked and almost scrapes...
yep - my best bud helped me do it and we tried adjusting it several times - he worked for 6 years running an exhaust shop, and we finally gave up in frustration as nothing we did would get it to fit right. I asked around - seems like a lot of people actually had some issues with that one and getting it to sit right. We even got pics of people who had it on right - mine just doesn't fit or hang correctly at all.
Thats strage about the issues your having with your magnaflow catback, mine fit really well, and hangs nicely, I just installed my longtubes and found that the y pipe bangs like a bitch, after the instal, I found out that the best way to fix it is to instal poly mounts (got the heater hose mod in there for now) I looked back up in there and Im not looking forward to having to do those mounts now with my headers in there
Mine literally looks like it's about to fall off on the driver's side. But that'll get fixed by the exhaust shop.
