Solid Motor Mounts
Old 06-19-2009, 08:38 PM
web8745's Avatar
Default Solid Motor Mounts
I am going to install my solid motor mounts tomorrow. I did a search but did not find much info on tip to installing them ... Just that they suck to change.
Anyone have any info that will help me?
Its a 1999 Camaro with Long tubes ..
Think its hards with the long tubes..
Thanks for your help...
Old 06-19-2009, 10:01 PM
SS1875's Avatar
Maybe this will help: https://ls1tech.com/forums/generatio...ion-motor.html
Old 06-19-2009, 10:10 PM
ChevyRyda99LS1's Avatar
the poly trans mounts do cause some vibration I got mines in when you really get on it and the mph starts to get high you will hear it pretty decent
Old 06-21-2009, 08:26 PM
Arc00TA's Avatar
Any word on how this went? I think I am going solid just to save the hassle of trying to press the poly ones into the clamshell and all that jazz. I don't mind vibrations, my car has felt like one of those homedics chair cushion massagers since I've owned it anyways.
Old 06-22-2009, 06:32 AM
outkast6991's Avatar
the install isn't that bad. you will need to drop the alt and make sure you have a 13mm gear wrench( it is a life saver). do one side at a time and leave the bolts loose until you get both sides with all the bolts threaded. patience is your friend
Old 06-22-2009, 08:32 PM
OUTLAWZ RACING's Avatar
Im with outkast, Thats the way we done it. Mind you those sphon solids will rais the motor up. I can remove my oil pan with out raising the motor now.
Old 06-22-2009, 08:39 PM
lowaggie's Avatar
It's not too bad. Though, make sure to disconnect the little wire connector on top of the alternator before you drop it. I found out the hard way when I pulled that wire loose. Luckily, I was able to make a new connector. Just be careful.
Old 06-22-2009, 10:54 PM
Cthulu's Avatar
HOLY CRAP ON TOAST, that reason ALONE is worth getting solids...pulling the pans on the fbods is a HUGE pita...with solids I can pull the pan and replace my mains...with the motor in the car and attached! Brilliant!
Old 06-22-2009, 10:57 PM
ShortChevy's Avatar
When I put mine in I didn't mess with the starter or alt. I did mine at the same time I put headers in though. Tons of room with no exhuast or manifolds in the way. I did the driverside first and then the pass. Just stick a jack and a chunk of wood under the oilpan and it's a breeze.
