Anyone successfully remove the OPSU on LS6 IM swap?
I'm trying to see if anyone has successfully removed the Oil pressure sending unit from the back of intake when doing an ls6 manifold swap. I really don't want to buy a new one. Is there a tool you can buy to help you remove it?
Also, is a tune needed to experience gain in hp/tq after the install?
A regular deep socket won't cut it, you will have to find an extra long deep socket to reach the bottom and yes it is 1 1/16. I found it a little difficult to use an open wrench cause of the clearance to the firewall. So I just went ahead and replaced it with a new one since I figured it's 11yrs. old it will probably break soon so I replaced it.
