which y pipe?
Old 08-28-2009, 08:44 AM
kevins2000LS1's Avatar
Default which y pipe?
going to order the pacesetter long tube package from TSP here soon and seen that you can get the pacesetter ypipe or the TSP pipe. Have you guys experienced a better quality between the two?
Old 08-28-2009, 08:46 AM
Cohi's Avatar
Assuming you are going with the offroad y-pipe?
Old 08-28-2009, 09:18 AM
MjMaro's Avatar
The Pacesetter ORY will give more ground clearance due to the spots where it is flattened slightly. The TSP pipe will give you a bit less restriction based on it being tubular throughout, either one will work, just depends on your personal preference.
Old 08-28-2009, 09:32 AM
TXZ28LS1's Avatar
i run a pacesetter longtube with a pacesetter ory and i have no issues at all. fitment and everything was good.
donman's Avatar
I asked the same question from Texas speed and and MjMaro is correct. I order my stuff last week, unfortunately some of it is on backorder..
Don
Old 08-28-2009, 09:42 AM
03Sssnake's Avatar
I used to have a Texas Speed off-road y-pipe with QTP LTs, personally thought it was garbage, the merge was horrible and I had lots of rasp. I believe Texas speed has recently redesigned their y-pipe with a better merge. In any case... I have since changed my entire setup to ARH Longtubes with catted y-pipe and have not looked back.
Old 08-28-2009, 10:20 AM
thanks for the input guys keeep it coming
Old 08-28-2009, 10:32 AM
twitchtwice's Avatar
i vote TSP if you are on a budget and dont feel like dropping an arm and a leg for arh. i just bought their TSP's new catted y and it has amazing fitment and the new merge is well designed. i switched to a ypipe/ magnaflow cb from a td exhaust and noticed no loss in SOP and it still sounds good too.
Old 08-28-2009, 10:49 AM
Brandon35thSS's Avatar
i got the tsp y and it fits great and no ground clearance issues at all. tsp ftw!!
Old 08-28-2009, 11:26 AM
Grifter's Avatar
Custom. No worries about whether it will fit or not.
Old 08-29-2009, 02:25 PM
ok so im leaning toward the TSP one!
