85mm tb and ls6 install.... not what i was expecting...
Old 08-28-2009, 01:31 PM
bongva's Avatar
Default 85mm tb and ls6 install.... not what i was expecting...
Ok so I'm kind of in a dilemma here... I installed a Professional Products 85mm TB the other day along with the ls6 intake. I feel as if up top from 4500-6000 my car is not running as strong as the stock TB and LS1 intake. I know the ls6 intake wouldn't make me lose power... So im leaning towards the TB... It came with all sensors so I just plugged it up and drove it around. Now can i just plug it up like that and drive it? or do I need to adjust the TPS and what not?
maybe the TB is overkill???
or maybe is it just my butt dyno? i feel like i lost a little tq as well....
What are you guy's thoughts?
Thanks,
Lee
edit: the car was tuned before the intake manifold and TB install. perhaps it just needs a tune now?
Old 08-28-2009, 01:38 PM
mph476's Avatar
what kind of supporting mods do you have done to the car. if you don't have anything else you'll lose a little on the low end with the bigger TB. but if you're losing up top you might need a tune.
Old 08-28-2009, 03:24 PM
bongva's Avatar
the car was previously tuned. i have the basic mods of LTs, ORY, lid. it made 349rwhp 361tq.
Old 08-28-2009, 03:59 PM
tittan1500's Avatar
did you check to make sure the throttle body was opening all the way?
Old 08-28-2009, 04:31 PM
bongva's Avatar
i think it is, can i just look at the TB opening and guess that it is 100%? or do i have to hook it back up to HPtuners and get a TPS reading off of that?
Old 08-28-2009, 04:34 PM
IWGF's Avatar
TPS reading will be most accurate, but if you wanna eyeball it, and it's not opening all the way, grind down the stopper tab a bit, it'll let it open more.
Old 08-28-2009, 05:36 PM
tripblackls1's Avatar
there is an adjustment screw on the pp 85mm tb for idle and wot
Old 08-28-2009, 05:47 PM
NemeSS's Avatar
check to see if physically openeing correctly, and also have to go thru tune.
to see if all is correct.
Old 08-28-2009, 06:04 PM
Summerwolf's Avatar
needs to be retuned after changing to the LS6 intake.
Old 08-29-2009, 12:53 PM
bongva's Avatar
ok so the throttle body is openeing correctly, and it is getting 100% thorttle according to HPtuners....
any other thoughts?
Old 08-29-2009, 04:32 PM
LS1-450's Avatar
any other thoughts?
Since you have HPtuners, you're all set. Just run an AutoVe & then re-scale the MAF table.
Old 08-29-2009, 07:29 PM
studderin's Avatar
I dyno tested this, same time right on the dyno.....
https://ls1tech.com/forums/generatio...vs-fast92.html
Old 08-30-2009, 02:45 PM
bongva's Avatar
I dont have it, I was just using my buddies to log my car. and Im also on speed density.
Old 08-30-2009, 02:54 PM
bongva's Avatar
excellent information!!!!
but now the problem is, i think that my car with the ls6 intake and 85mm tb actually runs worse than the ls1 intake and stock tb.
so i thought that it was the 85mm tb, i took it off last night and put the stock one back on. (left the ls6 intake on the car). ran a buddy of mine that i always run, with the stock ls1 intake/tb i would get him pretty hard, but with the ls6 intake and stock tb, he was at my door!!! not sure wants going on anymore. might just do a full maintence on the car then throw it on the dyno and go from there.
any input u guys have is greatly appreciated!
Old 08-30-2009, 08:58 PM
LS1-450's Avatar
OK, then you need a new SD tune. Swapping an intake & TB while on a SD tune with no re-tune is dangerous. I'd bet she's running lean & pulling timing due to knock. There's the power loss. With no fuel trims to correct the increased airflow into the heads, she's running lean. At the very least, modify the OL fuel table & the PE table to increase fueling.
Old 08-30-2009, 09:21 PM
rice4eatingnotdrivin's Avatar
not to take over ur thread bongva but just curious im still new to the entire LS1 motors but would the 85mm tb and ls6 intake be one of thoughs mods u would want to do after u put in a decent size cam? in my opinion u are better off running stock intake and TB until u do a cam. is there some truth to that?
Old 08-31-2009, 12:14 AM
camAro242's Avatar
you def need a tune
Old 08-31-2009, 04:19 AM
SS4Luck's Avatar
the ls6 intake came stock on 01-02 cars so it is "stock" when you get down to it. Most people swap out the Ls6 intake for a Fast 92/92 or so when they get a cam that is aboe 233 duration
Old 08-31-2009, 09:24 AM
bongva's Avatar
Oh ok I see, excellent, I will try to get a tune asap then! thanks for the help!!!!
also another question, when we did my log, my buddy said that i was at 100% duty cycle.... is that correct? i mean on just bolt-ons can i really max out my stock injectors?
Old 08-31-2009, 09:51 AM
Johnnystock's Avatar
He said it. LS1 intake is crap compared to LS6. With a tune, you'll beat up your buddy more than before.
