Accufab 4150 4 BBL TPS replacement
Old 10-02-2009, 07:31 AM
1CAMWNDR's Avatar
Default Accufab 4150 4 BBL TPS replacement
Do any of you folks know the part number for the Accufab 4150 TPS? I know it is a GM late model TPS, and I bought one from Advance Auto that looks right and fits right (97 LT1 F-body I think it was), but on HP Tuners it reads 13% when the throttle is closed, and then as I push the accelerator pedal it goes DOWN to 0. Have any of you had problems with the LS1 computer reading the correct throttle position on an Accufab 4 BBL?
Old 10-02-2009, 12:31 PM
1CAMWNDR's Avatar
I think I found the problem: From pics of the LT1 throttle body the throttle position sensor is on the correct side (passenger side) like the Accufab, but the LT1 opens pulling from the bottom rotating in the oposite direction from the LS1 throttle bodies and the Accufab. So, now I need to find out if anyone knows of the same style throttle position sensor that operates in the oposite direction of the LT1 .
Old 10-04-2009, 05:40 PM
1CAMWNDR's Avatar
Yep, the LT1 TPS rotates in the wrong direction. Autozone had a Duralast TPS from a 1994 Chevy 1500 5.7 TBI that works correctly. The Autozone stock # is TPS112. $29.99. It reads correctly.
Old 09-19-2010, 12:54 PM
1CAMWNDR's Avatar
Well, it read % correctly andmade the car run, but not great. Turns out the voltages were not correct. I finally just ordered a TPS from Accufab and it is idling correctly, and going to PE at WOT now!
Old 09-19-2010, 01:04 PM
IH8FORD's Avatar
My accufab 4150 uses a regular ls1 TPS sensor if I am not mistaken.
Old 09-28-2013, 10:17 AM
Jimmy_d's Avatar
I know this is an old thread,but im having a prob with my 4150 ,brand unknown, bought a lt1 tps and throws a low voltage code, have a gm tps that was on it and it throws a high voltage code and a ls1 tps wont fit.... Not driving car because i dont want to smoke the trans with bad tps
Old 09-28-2013, 07:43 PM
IllusionalTA's Avatar
Are you able to check the actual operation of the rod? I believe the lt1 tps spins cw you may need a ccw one off a 5.7 tbi truck...
Old 09-28-2013, 09:16 PM
Jimmy_d's Avatar
Yeah. the throttle body has no name numbers or markings. I've seen some take a ford late Model and some take a gm.. I've got a tbi one coming. Just gonna have to check the volts and % when it gets here.. bought the car with few mods, gonna have to learn more about it lol
Old 09-29-2013, 08:10 PM
S10xGN's Avatar
Does it look like this? I got this off E-Bay for a fair price, it's a Force brand.
Old 09-29-2013, 08:30 PM
http://item.mobileweb.ebay.com/viewi...d=190836165084
Old 09-30-2013, 08:18 PM
Jimmy_d's Avatar
It looks exactly like a sullivan 4150 tb.. But im not sure lol.
Quick Reply: Accufab 4150 4 BBL TPS replacement
