TSP True Duals guys come in
Old 10-07-2009, 02:28 PM
hlaalu's Avatar
Default TSP True Duals guys come in
Might be a stupid question, but where do I hook up the hangers under the car? Do I have to screw them into the bottom of my car?
Old 10-07-2009, 02:32 PM
6.0 silverado's Avatar
A few people have used the rear seat belt bolts, but I just drilled a couple holes and used some fender washers.
Old 10-07-2009, 02:34 PM
94'BLKBRD's Avatar
Weld them on or drill holes thru the back seat area. I had mine bolted on to the back seat area. I didn't have access to a welder.
Old 10-07-2009, 03:17 PM
99_Z_155's Avatar
I drilled holes and bolted them in the rear seat area as well. tuck em up as close as you can. you wont regret the sound.
Old 10-08-2009, 07:26 AM
BlackBADaSS02's Avatar
When I had them, I drilled holes in the rear seat area an bought some bolts & washers from Lowe's.
Old 10-08-2009, 09:26 AM
hlaalu's Avatar
Thanks for the replies, going to put them in this afternoon. I'm going to flip that fuel line bracket as well I think to get them as tucked as possible.
Old 10-09-2009, 07:06 PM
MonkeyBoneSS's Avatar
How low is your suspension ? Was it difficult to get them to tuck up ?
Old 10-09-2009, 07:23 PM
KingOfCold's Avatar
I shortened the hangers by about 2 inches and then welded them to the rear seat floor pans. Also, a tubular torque arm allows for much more clearance. The only part of the exhaust you can see is the turndowns, but only from the rear.
