Stock FAST throttle body hole size?
Old 11-10-2009, 05:52 PM
thunderstruck507's Avatar
Default Stock FAST throttle body hole size?
I have a used fast 90mm tb that the previous owner drilled a larger hole in for a big cam.
I want to get it filled and put a stock size hole back in, does anyone know what size it is?
Old 11-10-2009, 06:48 PM
NBM-LS1's Avatar
I think is around 2mm.
Old 11-10-2009, 06:57 PM
SweetS10V8's Avatar
I dont think they have a hole at all....
Old 11-10-2009, 11:07 PM
rock your world's Avatar
do u want to sell it
Old 11-11-2009, 07:04 AM
toadzq8's Avatar
The Fast don't come with a idle air hole.
Old 11-15-2009, 06:41 PM
disc0monkey's Avatar
i just spent three months working to get stock-like750rpm idle and startup on a 5.3 head 218/224 on 116 cam ls1. we tried many different hole size and blade adjustments working with hptuners. finally, i went against my logic and welded up the hole and adjusted the blades close to the region where it would just not stick(or slightly open) and gained great startup response, less bucking and the smooth idle. relying on mainly iac control, rather than something as static as a hole and/or opening the blade has given better results. just letting you know what worked for this car.
Old 11-15-2009, 09:00 PM
it idled up to 1200rpm with the hole open, i put a bolt/locknut/loctite in to see if that helped and it would not start and run until i cracked the blade with the set screw
maybe my IAC is going bad...the car still doesn't like to idle sometimes...sometimes it randomly starts surging
Old 11-15-2009, 09:54 PM
are you resetting the computer each time?
everytime before i started to take the throttle body off for adjustment i just went ahead and pulled the fuses to reset the computer. by the time i had the TB back on the computer was reset. I don't know exactly how far my TB is from being shut but i believe it is very close. I have reason to believe with no hole and blades entirely shut it, the car mentioned previously would idle purely by passage of the iac.
if i were you i would keep the hole closed. adjust the screw so the blades are closed(slight stickiness). with resetting the computer each time. keep opening the adjustment screw 1/8 of a turn.(you have a bigger cam so you'll need the blades opened slightly more than me. until it starts getting worse and back it off 1/8 and you found your sweet spot. obviously let the computer learn the idle after like 3-4 min. turn the car on and off a few times and take it around the block.
this is such a pain in the *** but bite the bullit to get that car to run perfectly and it'll be worth it.
gm sucks for designing the TB so we arent able to adjust the screw while on the car.
carburators +1
Old 11-15-2009, 10:01 PM
eseibel67's Avatar
You can adjust the set screw on the car, but it's a pain in the ***.
Use a 1/4'' drive breaker bar (seriously, they exist) and a torx bit (forget the size) that has some of the end ground off. It fits under the TB just above that roundish part of the water pump.
Old 11-17-2009, 08:04 PM
I'll try to pay with it some then. Thing is I had it running great for a while, then 1 day it just decided it wouldn't start and run until I opened the blade up some more. Got it running good again and one night at the track I made 4 passes, on the 5th I had to double foot the brake and throttle to keep it running at the line.
Old 11-18-2009, 05:53 AM
toadzq8's Avatar
Pull the TB and remove the idle screw and reinstall it unside down then you can get to it and be able to adjust with the TB on the car.
Old 11-18-2009, 09:07 PM
I can adjust it on the car, just have to leave the car off and pull it to WOT so the allen head is easy to get to.
I was just hoping there was supposed to be a hole so I might have a clue why it randomly acts up on me.
Quick Reply: Stock FAST throttle body hole size?
