Name that liquid in my catch can (pics)
Old 12-12-2009, 08:02 PM
speedfreak2685's Avatar
Default Name that liquid in my catch can (pics)
I have been pulling this liquid out of my catch can (revextreme) since I purchased it about 3 months ago or so and was told it was just condensation but this kinda seems too extreme to be condensation? It kinda worries me. The amount drained in this jar is from about 775 miles worth of driving without emptying the catch can. It led me to believe there was a head gasket leak because of so much of this comeing out of the can but I did a coolant system compresion check with the pump thing on the radiator and it held pressure just fine. My radiator is still full of coolant as well as my coolant resevoir. I would think if all that liquid it was pulling out was coolant then I would definatly have noticed the coolant resevoir being low. If I pull the oil dipstick out it shows no signs of water in the oil. The oil fill cap will have a few drops of water under it and am about possitive that is condensation. It is really cold right now with the average temp probably around 40 or so. The average trip in the car is about 20 miles or so with a occasional long trip. It sits all week and driven on only on most weekends about 300 miles a month or so. I know the brownish liquid on top in the jar is oil which would be normal but what the heck is all that other liquid? It is driving me nuts!
Old 12-12-2009, 08:15 PM
jomomma's Avatar
it looks just like whats in my catch can. its condensation/oil. i have an aluminum block. every time i drive mine i get about an ounce of that crap in my catch can. i have dumped it after the motor warms up and continued driving and wont get any more in my catch can until i do another cold start up. you should try this just to see what happens.
Old 12-12-2009, 08:19 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Looks like beer dude. Your car been going out without you?
Old 12-12-2009, 08:22 PM
haha, I hope not!
Old 12-12-2009, 08:25 PM
Interesting. I have a alluminum block as well. I will give that a shot.
Old 12-13-2009, 01:56 AM
RooRnZ28's Avatar
i get the exact same **** in my cc.... its just oil/condensation.
Old 12-13-2009, 02:13 AM
mathia's Avatar
I just moved to Milwaukee and I've noticed I get a lot more of this oil & water in my catch can than when I was in Los Angeles. Certainly makes sense since LA is a desert, but I'm surprise how much more I get here. There was hardly of this crap, usually just got oil, when I was in LA but here I was getting lots... until I put my car away for the winter a couple weeks ago
Old 12-13-2009, 07:38 AM
ls1psycho's Avatar
how is your catch can routed in your pcv system? are you still running a pcv?
Old 12-13-2009, 08:55 AM
It is definatly hooked up right. The catch can has a built in pcv.
Well I guess it is just condensation then from what you and everyone else are saying. It makes sense that both of us will be getting more "condensation" in our catch can because the colder it is outside the more water will be pulled to a hot surface (motor) from what I understand. I just thought it was kinda extreme with so much being in my can.
Old 12-13-2009, 09:28 AM
cabotgsxr's Avatar
after seeing this im glad i just ordered my catch can.
Old 12-13-2009, 02:08 PM
Very true. Im just glad im getting all this crap out of my motor!
Old 12-13-2009, 03:35 PM
01'SSLSX's Avatar
i dont see any water at the bottom of jar. (water is heavier than oil). so i think u'r ok
but i dont know what that junk is on top in jar, lol
my catch can collects only oil so who knows
Old 12-13-2009, 03:51 PM
The stuff in the top of the jar is water (condensation) mixed with oil I believe. Hence the milky brown color.
Old 01-02-2010, 11:22 PM
white01ss's Avatar
Default where's it mounted?
I'm seeing this as well. Smells and looks like an oil/water mix. The catch can used to be mounted to the passenger side cylinder head and would get hot along with the engine. Mounted there I never saw this type of fluid in the catch can, only oil. Since it's been relocated off the engine I've been getting lots of water. It's been cold here as well so I guess it's consistent with other guys. Maybe I'll just put it back on the engine and call it a day.
Old 01-02-2010, 11:34 PM
Pontiacerator
RevGTO's Avatar
Mine is on the pass cyl head and I only see oil.
Old 01-03-2010, 07:52 PM
max_ta's Avatar
RevExtreme on mine with same fluid coming out,also have LS6 valley plate
Old 01-04-2010, 09:12 AM
TLewis4095's Avatar
The colder it is, the more moisture it will collect (it will keep most as steam when the can is mounted on the head as long as it is run enough and let it pass through).
Old 01-04-2010, 10:32 AM
teke184's Avatar
Tracy
is it better to mount it on the head to keep the water as vapor? or to mount it on the side to let it condense?
ps...you'll be getting an order for a CC from me soon...yay 3 paychecks in Jan 2010!!!
Old 01-05-2010, 05:30 PM
TLewis4095's Avatar
Originally Posted by teke184
Tracy
Here in FL and other warm states (at least it USED to be warm) the cooler the better, but they do fine on the cylinder head. In Northern cold climates I would say the cyl head. The water as vapor pulled through does not affect performance and is fine going through the combustion chamber, but if it is cold enough to congeal or freeze, you will have draining issues and you don't want a full can.
Quick Reply: Name that liquid in my catch can (pics)
