air 2 fuel ratio
air 2 fuel ratio
I just got my car dyno the other day.With 6 bolt ons i made 330hp at wheels and 344ft pounds of torque.My air 2 fuel ratio was in the 14.0.Is that good or is it running 2 lean?I have a 2002 fire bird formula.
You first step should be to CARFULLY and THOROUGHLY clean your mass air flow sensor. Thats usually the first cause for going lean at full throttle...it's usually either dirty (oily from filter oil or something else) or broken.
You can monitor the mass air flow sensors reading at full throttle as well, it should be a smooth reading, usually when they're having problems, at full throttle, the readings get very unstable and messy...and low.
My a/f was a straight line at 14.0.I was told gm like to run lean.I will check my maf snice it's an aftermarket one.With 6 bolt ons it shouldn't make that big of difference with running lean i have nothing major done to the car.Maybe i need to have sumone add more fuel to it.
