LS1 Style heads fit on LS3 block?
I have the trickflow 215cc heads on my LS1 at the moment. I was wondering if I bought a LS3 block, would the heads be a direct bolt on to that block? I understand that the heads on the 2 motors are different but do they bolt the same way and would this work? What else would need to be changed? Thanks
Because of their comparatively small bores—3.89 inches—LS1 and LS6
engines can only use LS1, LS6 and LS2 heads. Using heads designed for
larger engines will cause valve-to-block interference. The larger, 4.000-inch
bore of the LS2 enables it to use LS1/LS6 heads, as well as L92-style heads
(including LS3, LS9 and LSA). The 6.2L engines (LS3, L92, etc.) can use all
production heads except for the LS7, while the 7.0L LS7 and C5R blocks
can use any LS-Series head. LS7 blocks should be matched with heads
designed for at least 4.100" bores; 4.125-inch bores are preferred
so the answer is , YES
Why would you think I could make more power with the L92 heads over the Trick FLow 215cnc heads I already have. The L92 heads do flow a little better but we all know that CFM isn't everything. You might make more peak power with the L92 heads but I can almost promise you that you won't make as much across the power band than the Trick Flows. Using these heads with the larger motor will increase the compression ratio to around 11.8-1 and make tones of torque very early in the RPM range. Thanks again man.
I want to bring this thread back. Using the ls3 valley cover with ls3 block. Using ls1 style heads and intake.... will a factory ls1 oil pressure sensor screw into the ls3 valley cover?
