96mm typhoon intake any good??
Old 03-09-2010, 04:07 PM
batman_ls1's Avatar
Question 96mm typhoon intake any good??
whats up guys i just got a 96mm typhoon intake 95mm tb and i was wondering if its a good intake or not over like the ls6 iv seen people saying there making 17hp more than the ls6 but just want to see what other people think??
Old 03-09-2010, 04:46 PM
brian_rs/ss's Avatar
isn't the 96mm based off of the ls2 intake? i would also like to hear some input on this intake.
Old 08-19-2010, 01:59 PM
taman86's Avatar
bringing this back from the dead....i have a 96mm ls2 style typhoon. i havnt had a chance to install it yet but one thing that im trying to figure out right now is 1) the map sensor is located on the front of the intake instead of the rear like a standard ls1 so im not sure if this will cause problems with the computer not reading the map sensor correctly, and 2) there are vacuum lines located on the back of the engine which would normally be attached to a nipple on the back of standard ls1 intakes but this ls2 from typhoon has no provisions for it and i have a thread up asking about my problems and what have people done to overcome this issue. but other then that it should be a fairly good install with minor issues.
Old 08-19-2010, 05:34 PM
slo98z28's Avatar
good info
Old 09-05-2010, 03:27 AM
DGageSS's Avatar
ya good info but wrong intake. you have the ls2 my friend. i just finished my 408 with the 96mm LS1 intake and it is correct. the t in the back and the map in the back. you just have the wrong intake, but you might be able to do something that are correct. All i know is people talk **** about the typhoon but i started my car and had to make no fuel rail adjustment and the intake wasnt leaking air so fromk what i saw we were good. its a nice piece.
Quick Reply: 96mm typhoon intake any good??
