Ground wire on wiring harness question
On the drivers side theres a copper braided wire thats taped to the wiring harness but doesnt touch the other wires its taped on the outside of the wires that go to the o2 sensor and the alternator. Does any one know the signifigance of this and where i should ground both of the ends? If this isnt a good enough explination ill try and find a picture.
Engine to chassis ground
Its a redundant ground to maximize contact between the battery, chassis and engine block for the least possible resistance back to the battery post
I would suggest reattaching it. The spot you ground it from/to is irrelevant, just be sure the areas are clean
