Pcm ground question, engine will not fire up.
Old 04-03-2010, 12:52 PM
boosted4life's Avatar
Default Pcm ground question, engine will not fire up.
I was wondering how the pcm grounds? I have been having problems with my 98 ss camaro ls1 after a motor install and it will not fire up. The local gm dealership told me they corrected a few wires but it needed a new pcm, I installed a new pcm and it still will not fire up just doing the same things as before. Any help would be great..
Also there is a braided flat ground strap on the driver side, I was wondering where that connects to?
Old 04-03-2010, 04:31 PM
nobody?
Old 04-04-2010, 03:41 PM
Old 04-04-2010, 04:12 PM
sjsingle1's Avatar
that braided strap bolts somewhere behind the ALT.....but there is also a ground from the BATT right above the starter
Old 04-04-2010, 04:42 PM
Thanks.. and I got the ground near the starter.
Old 04-04-2010, 05:04 PM
dgcustomz's Avatar
There is also a ground in the back of the driverside cylinder head. Did you hook that one up? It comes out from the wiring harness at the back of the driver engine bay.
Old 04-04-2010, 06:53 PM
Yea that's hooked up..
Old 04-05-2010, 09:34 AM
Any more ideas on what is causing it to not start??
Old 08-30-2012, 03:17 PM
Ws6kid.'s Avatar
Got a similar issue =/
Old 08-30-2012, 04:08 PM
LS1MCSS's Avatar
How many wires? There is more than one wire.
Quick Reply: Pcm ground question, engine will not fire up.
