Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- Camaro and Firebird: How to Replace Oil Pressure Sensor
Step by step instructions for do-it-yourself repairs
DIY - Junkman's Engine Oil Pressure Sensor Replacement/Relocation for Dummies!
#41
Yep, got her done and I didn't have to take off the manifold. Just took forever cuz had to wait for the part store to deliver from hub and the rain to give me a couple of lucky breaks. She's good now and finally reading some good PSI on the oil gauge.
#42
Some guys just move the manifold forward and then change the EOP sensor. I like to be able to see every thing that I am doing and thus, I'll take as much stuff apart as necessary. For me, it's more about learning than the actual fix. I like taking stuff apart and then putting it back together.
#45
Used the guide word for word to install my fast 90. I think I have a vac. leak somewhere. After I installed it idles at 1.5k and idle stays up when I give it gas. I'll take another look at it in 2 or 3 days had enough for now.
Side note: I can't thank you enought the write up it was perfect!!!! Espically all the b.s. behind the intake.
#46
#49
figured out my problem. Sticking throttle body. Gonna work on it tomorrow. If you lived closer I would buy you a couple beers!!! This write up trumps anything I have seen on ls1howto.com, etc...... It is great b/c you can use it as a reference for just about anything!
#50
Thanks man. I have to give credit also to the guys in this thread who read it and corrected my mistakes. They helped make it as useful as it is. Thanks for letting me know that it worked for you also.
#51
A buddy of mine felt the same way so he built his own using the same exact parts. He saved $10 bucks. After all the running around that he did locating the parts, he wasted that much in gas!
#54
I read the write up, I'll admit rather quickly but was very appreciative of the info. I have a couple questions, though. I know that the kit works on f bodies. (I have a 2002 Z28) I'm currently leaking heavily through this sensor. I installed a gang of parts and I also installed a HV oil pump from Melling Select Performance. Before I started leaking I checked and the gauge returned to zero after I turned the key. When I started the car I'd idle at 60 pounds and when I ran, depending on the RPM, I would vary between 60 and 80 pounds. I read the "engine can't produce more pressure" on your write up. I'm assuming that this is stated for a stock oil pump?
I saw your relocation kit and I would love to know where I could buy it. I was directed to a link and the product was no longer available. I see that the crush ring is included, Do I need to add an additional sealer? I'm favorable to Teflon w/ Locktite. I use the stuff on my NO2 AN fitting. I thank you in advance for reading this lengthy post.
#55
When I stated that the oil pump cannot make more pressure than it is designed to make, I was talking about a stock pump but my statement is based on logic (as my mind works anyway). If a stock or aftermarket pump is designed to make 60psi for example, and you put it in a brand new motor, then the maximum oil pressure you should ever see is 60psi's because that is what that pump was designed to produce. As your engine wears over the years and parts begin to grind away, the actual space inside your engine begins to grow. Now we're not talking about a lot, just tiny amounts. As this space grows, the maximum pressure you will see should start to slightly decrease because the oil pump is designed to work inside a engine with so many cubic inches. So aftermarket or not, a oil pump is designed to have a certain output and if working correctly or incorrectly, it can't produce more than it is designed to do, only less.
I didn't add an additional sealer as the gentleman who designed the kit told me that there was no need to. I checked his website and the kit appears to still be available. I don't know what link you followed but here is his website where you can purchase the kit. You can also contact him via this link. If you can't contact him (he may take a minute to return your call), let us know. I heard that he was in a freak accident and may not be doing this type of stuff anymore. You can buy the parts to make your own but I can tell you from experience that you'll only save about $10.
Lastly, let me add that I am no mechanic by any stretch of the imagination so my logic could be off. I'm just a guy who was fed up with being ripped off by dealerships and crappy mechanics so I decided to figure out how to do all the work on my Corvette myself. At least I do have the GM service manual so I'm not flying blind. If my logic is flawed, hopefully someone will chime in and educate the both of us. I'm all about learning and appreciate the feedback of guys here who actually know what they are doing. I am not remotely that guy.
I just know what I know.
#58
