DIY - Junkman's Water Pump Replacement for the C5
Well folks, you get to benefit from another situation I found myself in. The day before I was supposed to drive to Arkansas from Kentucky, my water pump decides to reveal to me that it was leaking. I had been smelling antifreeze but it wasn't leaving any drops on the floor. Well, that finally changed at the most inopportune time.
Some info on how to check for a leaking water pump. First of all, if you smell antifreeze, you have a leak. Period. You may not see it, see coolant on the ground or be able to locate it but trust me, you have a leak. I think I have managed to have a leak in every possible common location:
Here's the deal with detecting a water pump leak on the C5. The fluid will not drop to the floor directly under the water pump unless you have a really heavy leak. It will land on the belt or belt pulley and sling to one side of the car (most likely the driver's side because of the direction that the belt travels). I didn't know that as I kept checking dead center of the engine on the garage floor. My leak was extremely small up until the point that I actually found it. Hey, I'm old school and my previous experience taught me to check dead center of the engine on the garage floor. Now I know better. :lookinup:
This turned out to be a rather easy repair compared to some that I have done. I would easily recommend a shade tree mechanic take this on as long as you have one very important tool: hose clamp pliers. Don't even attempt this repair without them as there are quite a few hose clamps that you have to remove. Those things will take you forever to remove with a pair of pliers. Don't waste your time, buy a nice pair of hose clamp pliers with the extension cable. You'll thank me later. You'll see them in the pictures below.
With all that said, let's get to the repair!
Tools needed:
This repair should only be done when the engine is cool or cold.
Step 1: Remove the air cleaner intake duct. This is actually done as a unit. You don't have to remove the entire thing as I did, you can just remove the air bridge but for me, it was quicker just to remove the whole thing since I know how. Here it is removed:
To do this, pop up the pins that hold the air bridge onto the radiator shroud.
Unplug the mass airflow (MAF) sensor connector. Once you get it unplugged and the harness is disconnected from the clip that holds the harness down, move it toward the back of the engine out of your way.
Remove the air filter in order to make the next step simpler. As you can see, I'm a firm believer in the K&N filter.
This next part is kind of tricky the first time you do it. The air cleaner intake duct is held onto the front frame cross-member by 2 rubber grommets. The air box just pushes on and pulls off. The first time you do it is like pulling teeth because you really have to give it a tug. It gets easier to do once you've done it before. See pictures below.
You will also need to unplug the Secondary Air Injection (AIR) hose. The bottom part of that hose simply pulls apart from the top part if you twist it back and forth.
Last of all, loosen the screw that holds the air bridge onto the throttle body.
Once you get all this stuff disconnected, separated and unplugged, the air cleaner intake just simply lifts out of the engine bay. Put it to the side.
Step 2: The first thing you need to do here is look at how the accessory belt is routed. Take pictures of it from various angles so that you will have something to look at when it comes time to put it back on. That's what I do before disassembling anything.
Remove the accessory belt from the accessory tensioner pulley and allow it to drop toward the bottom of the engine. There is no need to remove it all the way so don't make more work by doing so. To remove it, use the 15mm socket and rotate the pulley clockwise (toward the driver's side), until you can slip the belt off the tensioner.
Step 3: Drain the cooling system. In order to do this, you will need to raise the car. for those who don't have a lift, here's the way I do it.
A) Drive the front of the car up on some 2X12's.
B) Using a low profile jack that I got from Harbor Freight, I center a 2X4 on the jack plate and run it under the front of the car.
Once in place and lifted, I support the car with jack stands.
I follow the same exact procedure for the rear of the car, making it slightly higher for draining purposes.
Warning: Pay special attention to the front jacks as you raise the rear. They could topple over if you get to extreme with your lift height!!!
Now I have all kinds of room to work under the car.
Remove the overflow tank cap and get your safety glasses on. Remember, safety first! :thumbsup:
The actual draining of the system is pretty easy. You simply loosen the drain **** (hey, I didn't name it... that's what it's called) and you will see the fluid begin to flow. You will turn it counter-clockwise. Do not completely remove the drain ****, just loosen it until the antifreeze starts flowing real good. Now go have Dagwood Pizza and your favorite drink because it will take the fluid a little bit to completely drain..
Once all of the coolant has drained, close the drain **** and lower the car. You can reuse your old coolant if you want to but if it wasn't changed recently, I don't know why you would. Don't be a cheap azz, buy some new fluid for your baby. Don't get the 50/50 stuff because you're paying for water, which is free (however, if you don't have access to distilled water, buy the 50/50 stuff). Other than that, buy the full strength stuff and dilute it with distilled water. You can use A 50/50 mixture of clean, drinkable water but use only GM Goodwrench® DEX-COOL® or Havoline® DEX-COOL® silicate-free coolant. It takes approximately 11.9 liters (12.6 quarts) to refill the cooling system.
- The "T" connector located on the surge tank (it usually cracks).
- The upper hose connector at the top of the radiator. It develops a hairline crack. There's a TSB that has you polish it out and not replace the radiator. I replaced my radiator instead because it had over 100,000 miles on it.
- The water pump.
Tools needed:
- Hose Clamp Pliers
- 3/8" 10mm Socket and Ratchet
- 3/8" 15mm Socket
- Flat Head Screwdriver
- Dielectric Grease or Vaseline
- Radiator Hose or White Lithium Grease
- Safety Glasses
- Another socket for the thermostat bolts but I forgot what size it was! :lookinup:
- These instructions! :thumbsup:
(con't)
Step 4: Get out your hose clamp pliers and reposition the inlet and outlet hose clamps at the water pump. See pictures below.
Step 5: Remove the inlet and outlet hoses from the water pump if you haven't already done so.
Step 6: Reposition the heater inlet and surge tank outlet hose clamps at the water pump. See pictures below.
Step 7: Remove the heater inlet and surge tank outlet hoses from the water pump, as per directions in the pics above (if you haven't already done so).
Step 8: In this order, remove the thermostat bolts (2), the accessory tensioner bolts (2) and the water pump bolts (6). One thing that I always do is ensure that I put the bolts I remove back into the exact hole that they came out of, especially when dealing with aluminum engine parts. Call me crazy, I have my reasons. If you want to do that also, make sure you keep track of the bolts as you remove them. Check the picture below.
Step 9: Remove the water pump. Nothing tricky here, just wiggle that chunk of metal out of there. Make sure you remove the water pump gaskets if they don't come off with the old water pump.
Clean up the area where all that Dex-Cool has leaked. You want to be able to detect any new leaks. I used Brakleen from CRC to clean up engine dirt. That stuff is good but you will need about 3 cans. You can go through that stuff pretty fast and it is not exactly cheap.
Now you're ready for the new pump. The new pump comes with the gaskets for the water pump and thermostat. The ones for the water pump are paper, which is NOT what comes stock on your car. Don't use the paper ones that come with the new pump, go buy the original GM gaskets. They only cost me $23, well worth the extra quality. Here's the gaskets and new part numbers as of this posting. You will need 2 gaskets (same part number).
You can use the rubber gasket that comes with the water pump for the thermostat. Just make sure that you replace that t-stat gasket!
New water pump. I paid about $180 at O'Reilly's for a brand spankin' new one.
Now all you have to do is reverse the installation process. Here's the fun hurdle that you will run into. Trying to keep the water pump gaskets in place as you line up the mounting screws and water pump. I could have used some type of grease to make the gasket stick to the motor or the water pump itself but I didn't know what was safe to use ( I didn't want to create any leaking issues). Thus, I spent the next two hours trying to do it without any help. It was a bitch.
Once I got it on, I went in and had another pizza.
One helpful tip: Use the dielectric grease or Vaseline on the rubber grommets that attach the air box to the front cross-frame. The grease will make it easier to snap back on. Use some radiator hose or White Lithium grease on the inner lip of the hoses to help ease the installation of them. DON'T use a lot. A teeny, weenie bit goes a long way.
Here are your torque settings for all the bolts.
That's it folks. It looks like a complicated job because I'm long winded and took a lot of pictures but it really is an easy fix if you don't know how to work on your Vette. With these instructions, anyone can do it.
Holler if you have any questions!
The Junkman
- Tighten the water pump bolts a first pass to 15 N·m (11 lb ft). Tighten the water pump bolts a final pass to 30 N·m (22 lb ft).
- Tighten the accessory drive belt tensioner bolts to 50 N·m (37 lb ft) starting with the lower bolt first.
- Tighten the water pump inlet bolts (thermostat) to 15 N·m (11 lb ft).
The Junkman
i got my WP at pimp boys for 110$.....its a bosch.....the same 1 is 180$ on rock auto.....go figure...and it came with gm style gaskets......no paper.....i used permatex red tack to hold the gaskets in place while i did the bolt up....i also put in a 160 stat....i do believe the stat gasket can be reused....no? i should have put in some ARP stainless bolts while i was in there.......you vette guys have so much room to work on engines.......me jealous!!!
old sarge USAF RET
old sarge USAF RET
old sarge USAF RET
old sarge USAF RET
This was a surprisingly easy repair. I checked a local shop and they wanted $200 in labor alone. I was like, "You smokin' crack?" I'll have to remember that Permatex stuff next time. I don't take any chances with gaskets. They are so cheap, once I break the seal, that puppy is getting replaced!
Whenever i have to take off a waterpump and put it back on with the gaskets and everything and i DONT have a helping hand, I put the gasket bolts thru the holes like u did in the picture with the gaskets hanging on the bolts. Then i mate it up to the holes in the block and just make sure that neither gasket has fallen at all or is uneven. I slowly hand-tighten the screws back in one on each side at a time until it can hold itself up with the just the bolts. I know the waterpump is heavy heavy but if you go in at a slight angle, it should work out okay. Just throwin it out there because you were talking about how it took you so long to get on. This was with an fbody too so there was less room to work. Its night and day between those two engine bays i tell you. At least you have the upper hand there junkman...nice writeup
I did it exactly as you described! I think because the car is so low and I'm no spring chicken, it was awkward to be leaning over the car that far with my back screaming at me! Now that I've done it once, it should be a lot easier. That was my first water pump ever. At least I picked a somewhat easy one to do! Thanks for checking it out!
Pendleton
Hey man are you still at Pendleton, if so we should go to the auto shop and do some work. I got a 99 Trans Am. I used your guides to change my knock sensors
If I was still there, you wouldn't have to ask twice. It would be a done deal. Alas, I left Pendleton in 86'. I'm back in Kentucky now.
GREAT write up!!!....Thank you !! Thanks for your service you guys The AF is sort'a the family biz around here, although I missed it (I'm'a Dumb ***). I was a dod civi for a while..lol.. no recall exercises..lol.. I'd like to go back to dod service some time soon.... Loved the write up, thank you!!...
