Left exhaust tip hotter than right?
don't see why it would be... the exhaust gas is just trying to find the easiest way out. Just so happens it's the driver side. Doesn't take much for one side to flow better than the other. Could be anything causing it. One pipe being higher than the other, one pipe having more turns than the other, a merge in the pipe not centered absolutely in the middle, etc...
No biggie... if the gas needs more room to exit, it's not like the passenger side is blocked off. It'll find it's way out that way if it needs to...
really.... it's nothing to worry about at all...
curious... what's your exhaust setup?
really it all just depends on the internals of the muffler and how everything is routed and baffled... plus if the muffler is mounted on a slight angle, hot air rises so your exhaust will try to exit out the side of the muffler that is sitting higher.
SLP lt's and ory with I believe a magnaflow catback. Car came with the catback and it has a magnaflow muffler so I'm guessing that's what it is.
