Delete A/C and Heat writeup?
anyone have a good delete write up with pictures and locations and yada yada yada. Im mainly interested in making sure i get everything plugged when i take them out. Ive looked around and cant find anything but a dash removal writeup and im looking to get this done in a night so i dont want o to struggle around for a few days trying tog et this done
I just got done deleting my A/C and heat.
Have you already finished deleting them?
Do you need any help?
Let me know, I will post pictures and tell you what I did. It turned out great.
Can I remove the 2 lines that I'm pointing to that run from the firewall to the waterpump? From the pictures, what else needs to be removed? Do I need to remove that entire black "box"?
Location: Your girl's back door giving her the long stroke while you're at work
You can remove the two ports on the water pump or just loop the line. If you want to fully remove the HVAC then yes you can take out the box but you'll have to pull the dash to get all of it.
Yea I think I'll just cut one of them and loop them. Quick question about that. If I remove those hoses to loop them, will any coolant or other liquid come out?
I'm going to leave the rest of it in there and just cap those two holes(Second picture, just right of the yellow dip stick).
Oh I didn't take a picture of it but the ac radiator is removed as well. I mainly removed this system because I bought the chris13131 ram air w/o ac from Speed Inc.
If you are just going to loop the hoses, You are deleting your heat... To keep the heat you must keep the heater hoses attached!!!! I have a shitload of pictures, as I just did this over last winter.. It is very involved if you want to keep the heat and lose the A/C. Let me know if you would like some Pic's posted.
