I need a better fitting lid...what are the best fitting lids?
Heres my lid that came on the car. Its and oldie. The tabs in the back dont even reach the slots so it looks like its not sitting down on the filter all the way. I need something better. Whats are the best fitting lids?
These lids are finnicky. Are you using a paper or K&N filter? I used to have a blackwing filter and my lid never sat right, switched to paper and it looks better.
Also, it looks like you pulled the factory bellows out, that may be part of what is pushing your lid forward. You might try and trim some of the end down a few millimeters at a time and see if that helps slide it back some.
I have a stock ss hood.
Yes,I had a MTI clear lid on my 98. I really liked it. After this one cracks I think I might end up with another MTI.
I run an FTP 85mm lid, it's got a nice tight fit. But, you have to run a coupler to connect to stock MAF and drill a hole for IAT sensor. WS6store will drill the hole for free for you if you buy from them. I really like it. It does rub on the hood a little, but not bad. You can put a little cushion or file a tiny layer of a lip of the hood where it hits. It's still a great lid and would get another.
If you want a clear lid definitely get the FTP over the MTI. FTP is stronger and won't crack as easily. I chose black for looks though
Yeah, but compare $300 for the Blackwing or whatever they go for to $85 for the SLP... most guys will sacrifice a little fitment...
Yeah, mine fit like a glove too. Apparently the new ones fit better. I ordered one for my last T/A a few years back and it fit like ****... this one is MUCH better.
i switched from K&N filter to wix paper filter last night. wix filter is a lot thicker than K&N and now I can see some of the orange edges of the wix paper filter. is this normal?
